Sony Xperia XA Motherboard Replacement
    1. Sony Xperia XA Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Apply heat on the back surface of the phone.
      • Continue to heat the device as needed throughout the replacement process.
      • The device can get very hot, so be careful when handling it.
      Ask FixBot
    2. Sony Xperia XA Motherboard Replacement: step 2, image 1 of 1
      • Stick the small suction cup on the bottom half of the back surface of the phone.
      Ask FixBot
    3. Sony Xperia XA Motherboard Replacement: step 3, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 3, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 3, image 3 of 3
      • With the bottom of the device facing you, lift up on the suction cup handle.
      • Use the plastic opening tool around all sides to pry off the back cover.
      Ask FixBot
    4. Sony Xperia XA Motherboard Replacement: step 4, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 4, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 4, image 3 of 3
      • Pull the back of the phone case away from the device.
      • You will hear popping sounds of glue being ripped from the phone.
      • You will hear the sound of the back unlatching from the device.
      • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
      • RAF antenna may be attached to the back cover upon removal.
      Ask FixBot
    5. Sony Xperia XA Motherboard Replacement: step 5, image 1 of 1
      • Apply heat to the copper RAF antenna.
      • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
      Ask FixBot
    6. Sony Xperia XA Motherboard Replacement: step 6, image 1 of 1
      • Peel back the RAF antenna.
      Ask FixBot
    1. Sony Xperia XA Motherboard Replacement, Motherboard: step 7, image 1 of 2 Sony Xperia XA Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Pry up the copper connector next to the battery with the plastic opening tool.
      Ask FixBot
    2. Sony Xperia XA Motherboard Replacement: step 8, image 1 of 2 Sony Xperia XA Motherboard Replacement: step 8, image 2 of 2
      • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
      Ask FixBot
    3. Sony Xperia XA Motherboard Replacement: step 9, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 9, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 9, image 3 of 3
      • Pry up the black camera case with the plastic opening tool and then remove the case.
      Ask FixBot
    4. Sony Xperia XA Motherboard Replacement: step 10, image 1 of 2 Sony Xperia XA Motherboard Replacement: step 10, image 2 of 2
      • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
      Ask FixBot
    5. Sony Xperia XA Motherboard Replacement: step 11, image 1 of 2 Sony Xperia XA Motherboard Replacement: step 11, image 2 of 2
      • Use the spudger to take off the connector in the top right of the motherboard.
      Ask FixBot
    6. Sony Xperia XA Motherboard Replacement: step 12, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 12, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 12, image 3 of 3
      • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
      • Peel back the tab past the connector.
      • Tab is stuck with adhesive.
      Ask FixBot
    7. Sony Xperia XA Motherboard Replacement: step 13, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 13, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 13, image 3 of 3
      • Pry up the camera's connector to the motherboard with the nylon spudger.
      Ask FixBot
    8. Sony Xperia XA Motherboard Replacement: step 14, image 1 of 2 Sony Xperia XA Motherboard Replacement: step 14, image 2 of 2
      • Use the spudger to loosen the black connector from the top right of the motherboard.
      Ask FixBot
    9. Sony Xperia XA Motherboard Replacement: step 15, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 15, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 15, image 3 of 3
      Tool used on this step:
      Buy
      • Pull out the square shaped connector using tweezers.
      Ask FixBot
    10. Sony Xperia XA Motherboard Replacement: step 16, image 1 of 2 Sony Xperia XA Motherboard Replacement: step 16, image 2 of 2
      • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
      Ask FixBot
    11. Sony Xperia XA Motherboard Replacement: step 17, image 1 of 3 Sony Xperia XA Motherboard Replacement: step 17, image 2 of 3 Sony Xperia XA Motherboard Replacement: step 17, image 3 of 3
      • Use the spudger to separate the motherboard from the frame.
      • Pull out the motherboard using your fingers.
      Ask FixBot
2 other people completed this guide.
Anthony Hernandez
736 Reputation
3 Guides authored
Cal Poly, Team S17-G2, Livingston Spring 2018 Member of Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 48
All Time: 3,066
