Sony Xperia XA Battery Replacement
    1. Sony Xperia XA Battery Replacement, Back Cover: step 1, image 1 of 1
      • Apply heat on the back surface of the phone.
      • Continue to heat the device as needed throughout the replacement process.
      • The device can get very hot, so be careful when handling it.
      Ask FixBot
    2. Sony Xperia XA Battery Replacement: step 2, image 1 of 1
      • Stick the small suction cup on the bottom half of the back surface of the phone.
      Ask FixBot
    3. Sony Xperia XA Battery Replacement: step 3, image 1 of 3 Sony Xperia XA Battery Replacement: step 3, image 2 of 3 Sony Xperia XA Battery Replacement: step 3, image 3 of 3
      • With the bottom of the device facing you, lift up on the suction cup handle.
      • Use the plastic opening tool around all sides to pry off the back cover.
      Ask FixBot
    4. Sony Xperia XA Battery Replacement: step 4, image 1 of 3 Sony Xperia XA Battery Replacement: step 4, image 2 of 3 Sony Xperia XA Battery Replacement: step 4, image 3 of 3
      • Pull the back of the phone case away from the device.
      • You will hear popping sounds of glue being ripped from the phone.
      • You will hear the sound of the back unlatching from the device.
      • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
      • RAF antenna may be attached to the back cover upon removal.
      Ask FixBot
    5. Sony Xperia XA Battery Replacement: step 5, image 1 of 1
      • Apply heat to the copper RAF antenna.
      • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
      Ask FixBot
    6. Sony Xperia XA Battery Replacement: step 6, image 1 of 1
      • Peel back the RAF antenna.
      Ask FixBot
    1. Sony Xperia XA Battery Replacement, Battery: step 7, image 1 of 3 Sony Xperia XA Battery Replacement, Battery: step 7, image 2 of 3 Sony Xperia XA Battery Replacement, Battery: step 7, image 3 of 3
      • Peel back the black tabs on the battery.
      • This may require some force as you are breaking the adhesive seal.
      • You will need to apply more adhesive for the reassembly.
      Ask FixBot
    2. Sony Xperia XA Battery Replacement: step 8, image 1 of 2 Sony Xperia XA Battery Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
      Ask FixBot
    3. Sony Xperia XA Battery Replacement: step 9, image 1 of 1
      • Use a plastic opening tool to get under the battery and pry it up.
      Ask FixBot
    4. Sony Xperia XA Battery Replacement: step 10, image 1 of 1
      • Lift the battery out with your hands.
      Ask FixBot
11 other people completed this guide.
Cassidy Davis
669 Reputation
1 Guide authored
Cal Poly, Team S17-G2, Livingston Spring 2018 Member of Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Members
96 Guides authored
1 Guide Comment
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 100
All Time: 6,146
