Sony Xperia T2 Ultra Dual Battery Replacement
Views: 17K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
107
All Time:
17,153
Comments: 3
3 comments on steps.
Completed: 25
25 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is to show what components need to be removed in order to replace your battery.
Tools
    1. Sony Xperia T2 Ultra Dual Battery Replacement, Rear Case: step 1, image 1 of 1
      • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
      Ask FixBot
    2. Sony Xperia T2 Ultra Dual Battery Replacement: step 2, image 1 of 1
      • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
      Ask FixBot
    1. Sony Xperia T2 Ultra Dual Battery Replacement, Removing the internal cover: step 3, image 1 of 1
      • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
      Ask FixBot
    2. Sony Xperia T2 Ultra Dual Battery Replacement: step 4, image 1 of 2 Sony Xperia T2 Ultra Dual Battery Replacement: step 4, image 2 of 2
      • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
      Ask FixBot
    1. Sony Xperia T2 Ultra Dual Battery Replacement, Battery: step 5, image 1 of 2 Sony Xperia T2 Ultra Dual Battery Replacement, Battery: step 5, image 2 of 2
      • Using the Tweezer, carefully pry open the corresponding chips that are attached to the battery as shown. Then using the spudger, pry the battery away from the phone and watch out for the sticky substance keeping the battery to the phone.
      Ask FixBot
25 other people completed this guide.
Christina Wojaczyk
1,450 Reputation
7 Guides authored
USF Tampa, Team 13-3, Staggers Fall 2014 Member of USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 107
All Time: 17,153
