Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓This guide is for replacing the battery in the Sony Xperia sola, model MT27i, also referred to as the Sony Xperia Sola or Xperia sola.
You may need to replace the battery if your phone no longer holds a charge, shuts off unexpectedly, drains quickly, overheats, or will not power on even after being connected to a charger. Replacing the battery can restore normal battery life and improve device reliability.
By following this guide, you will remove the old battery and install a replacement battery in the Sony Xperia sola.
Before beginning, power off the phone completely and disconnect it from any charger or cable. Lithium-ion batteries can be hazardous if punctured, bent, overheated, or damaged, so handle them carefully and avoid using metal tools when working near the battery or other delicate internal components. If the battery is swollen, leaking, or unusually hot, do not continue the repair until you can handle it safely.
Place phone down with screen side down and camera side facing up as shown.
Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
To remove the battery, slide the end of a plastic opening tool under the battery and lift it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler. For optimal performance, calibrate your newly installed battery after completing this guide.
3 other people completed this guide.
