Up to 20% off select tools
Sony Xperia S Disassembly
Views: 4.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
107
All Time:
4,249
Comments: 4
4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a step by step demonstration to disassembling the Sony Xperia S
    1. Sony Xperia S Disassembly, Sony Xperia S Disassembly: step 1, image 1 of 1
      • Remove the case (back cover)
      Ask FixBot
    2. Sony Xperia S Disassembly: step 2, image 1 of 1
      • Remove the screws in the indicated areas (Red Markings) with a screwdriver.
      Ask FixBot
    3. Sony Xperia S Disassembly: step 3, image 1 of 1
      • Then, detach the first bus (indicated with the red circle) to fully detach the case.
      Ask FixBot
    4. Sony Xperia S Disassembly: step 4, image 1 of 1
      • Then, you will see the battery, let's proceed to remove the battery.
      Ask FixBot
    5. Sony Xperia S Disassembly: step 5, image 1 of 1
      • To remove the battery, remove the two buses pointed out in red.
      Ask FixBot
    6. Sony Xperia S Disassembly: step 6, image 1 of 1
      • After removing the buses, we can remove the camera and the motherboard. Proceed to remove the motherboard.
      Ask FixBot
    7. Sony Xperia S Disassembly: step 7, image 1 of 1
      • Finally, after removing the motherboard, you have fully dismantled the phone.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order
3 other people completed this guide.
Special thanks to these translators:
es en
100%
Henry Ko is helping us fix the world! Want to contribute?
Start translating ›
Author
with
sergiolisto95
118 Reputation
1 Guide authored
4 Guide Comments
hi..my xperia s totally crashed..it is not working at all..is there any way to get the data from the sd card..!!??please help..if i disassembled it ..can i run the sd card on another device or something like that or any thing ..please help..:(
soma ana - Reply Share
Hi Soma Ana,
Assuming that your SD card has not been corrupted or anything, you can plug it into your computer or another device (though I would personally recommend you to look from your computer) and find your old files.
Henry Ko - Reply Share
estoy en la misma situación, pudiste encontrar la sd?
Leopold Fitz - Reply Share
،سلام، ال،سی،دی این گوشی چنده ، و از کجا بگیرم.؟
Mahdi siyah - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 107
All Time: 4,249
