Introduction
With this guide we will help you if you have a problem with the Loudspeaker and you want to disassemble the phone and change it.
Video Overview
Tool used on this step:iOpener$24.95
Warm the back cover using an iOpener or a hairdryer.
Use a small suction cup and plastic opening tools to carefully separate the cover from the frame.
Before reassembly, clean the frame from any old adhesive and apply new adhesive
Disconnect the battery cable from the motherboard.
The battery is secured to the phone frame with adhesive. Carefully use the white pull tab to remove it.
Li-Polymer Battery, 2230 mAh
Part number: LIS1551ERPC
Remove the two T5 screws.
Use a plastic tool to unstuck the the Loudspeaker module from the Main frame.
5 other people completed this guide.
1 Guide Comment
For anyone doing this on an Xperia M2 Aqua: BE VERY CAREFUL! There’s strong adhesive foam around the microphone (which points forwards and sits under the screen on the Aqua, unlike the regular M2 where it points downwards). Try your best to detach the loudspeaker module from the mic/vibra/antenna PCB first, then very, VERY carefully pry under the PCB with a plastic tool in order to release the adhesive. If you try to remove the whole assembly by lifting from a corner and pulling it sideways, you WILL break the main microphone. Why they’d put such a delicate component in an accident-prone spot is beyond me. Don’t get me wrong, it’s not an expensive fix, but the inconvenience will get on your nerves haha.
