Sony Xperia M2 Earpiece Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
100
All Time:
4,739
Comments: 3
3 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Very difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
How to disassemble the phone and change the Earpiece.
Please SUBSCRIBE to my channel ツ
Tools
Video Overview
    1. Sony Xperia M2 Earpiece Replacement, Rear Cover: step 1, image 1 of 3 Sony Xperia M2 Earpiece Replacement, Rear Cover: step 1, image 2 of 3 Sony Xperia M2 Earpiece Replacement, Rear Cover: step 1, image 3 of 3
      Tool used on this step:
      iOpener
      $24.95
      Buy
      • Warm the back cover using an iOpener or a hairdryer.
      • Be careful! The cover is made of plastic and can be easily deformed by excessive heat.
      • Use a small suction cup and plastic opening tools to carefully separate the cover from the frame.
      • Before reassembly, clean the frame from any old adhesive and apply new adhesive
      Ask FixBot
    1. Sony Xperia M2 Earpiece Replacement, Battery: step 2, image 1 of 3 Sony Xperia M2 Earpiece Replacement, Battery: step 2, image 2 of 3 Sony Xperia M2 Earpiece Replacement, Battery: step 2, image 3 of 3
      • Disconnect the battery cable from the motherboard.
      • The battery is secured to the phone frame with adhesive. Carefully use the white pull tab to remove it.
      • Li-Polymer Battery, 2230 mAh
      • Part number: LIS1551ERPC
      Ask FixBot
    1. Sony Xperia M2 Earpiece Replacement, Motherboard: step 3, image 1 of 2 Sony Xperia M2 Earpiece Replacement, Motherboard: step 3, image 2 of 2
      • Remove the SIM and the memory cards.
      • Remove 4x T4 Torx screws
      Ask FixBot
    2. Sony Xperia M2 Earpiece Replacement: step 4, image 1 of 1
      • Disconnect:
      • Touchscreen flex cable
      • Proximity sensor flex cable
      • Side buttons flex cable
      • SIM & Micro SD flex cable
      • Coaxial antenna cable
      Ask FixBot
    3. Sony Xperia M2 Earpiece Replacement: step 5, image 1 of 2 Sony Xperia M2 Earpiece Replacement: step 5, image 2 of 2
      • Disconnect the LCD Display flex cable located on the other side of the board.
      • Put a plastic tool between the motherboard and the frame.
      Ask FixBot
    4. Sony Xperia M2 Earpiece Replacement: step 6, image 1 of 3 Sony Xperia M2 Earpiece Replacement: step 6, image 2 of 3 Sony Xperia M2 Earpiece Replacement: step 6, image 3 of 3
      • Make sure to only use plastic tools, so you don't damage the board.
      • Move the left side of the board downward.
      • Take the left side out of the frame.
      • Take out the whole motherboard.
      Ask FixBot
    1. Sony Xperia M2 Earpiece Replacement, Earpiece: step 7, image 1 of 3 Sony Xperia M2 Earpiece Replacement, Earpiece: step 7, image 2 of 3 Sony Xperia M2 Earpiece Replacement, Earpiece: step 7, image 3 of 3
      Ask FixBot
3 other people completed this guide.
ZFix
197,729 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 100
All Time: 4,739
