Introduction
If your battery no longer holds a charge, this guide will show you how to safely open your phone and replace the old battery with a new one.
Video Overview
Tool used on this step:iOpener$24.95
Warm the back cover using an iOpener or a hairdryer.
Use a small suction cup and plastic opening tools to carefully separate the cover from the frame.
Before reassembly, clean the frame from any old adhesive and apply new adhesive
Disconnect the battery cable from the motherboard.
The battery is secured to the phone frame with adhesive. Carefully use the white pull tab to remove it.
Li-Polymer Battery, 2230 mAh
Part number: LIS1551ERPC
17 other people completed this guide.
