Sony Xperia L2 LTE Rear Camera Replacement
    1. Sony Xperia L2 LTE Rear Camera  Replacement, Battery: step 1, image 1 of 2 Sony Xperia L2 LTE Rear Camera  Replacement, Battery: step 1, image 2 of 2
      • Before disassembling the battery, power off your Sony Xperia L2 LTE.
      • Remove SIM card tray.
      Ask FixBot
    2. Sony Xperia L2 LTE Rear Camera  Replacement: step 2, image 1 of 3 Sony Xperia L2 LTE Rear Camera  Replacement: step 2, image 2 of 3 Sony Xperia L2 LTE Rear Camera  Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the back case of the phone off.
      • The fingerprint sensor is connected to the motherboard.
      • Disconnect the fingerprint sensor.
      Ask FixBot
    3. Sony Xperia L2 LTE Rear Camera  Replacement: step 3, image 1 of 1
      • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
      • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
      Ask FixBot
    4. Sony Xperia L2 LTE Rear Camera  Replacement: step 4, image 1 of 2 Sony Xperia L2 LTE Rear Camera  Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from the motherboard.
      • Pry up the battery and remove it from the device.
      • Battery may have adhesive that needs to be removed prior to removing the battery.
      • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      Ask FixBot
    1. Sony Xperia L2 LTE Rear Camera  Replacement, Motherboard: step 5, image 1 of 1
      • Unclip circuit connectors from phone to motherboard.
      Ask FixBot
    2. Sony Xperia L2 LTE Rear Camera  Replacement: step 6, image 1 of 3 Sony Xperia L2 LTE Rear Camera  Replacement: step 6, image 2 of 3 Sony Xperia L2 LTE Rear Camera  Replacement: step 6, image 3 of 3
      • Use blue plastic opening tool to pry off the motherboard.
      Ask FixBot
    1. Sony Xperia L2 LTE Rear Camera  Replacement, Rear Camera: step 7, image 1 of 2 Sony Xperia L2 LTE Rear Camera  Replacement, Rear Camera: step 7, image 2 of 2
      • Detach the rear camera from motherboard and remove it from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 45
All Time: 470
