Sony Xperia J SIM Card/Micro USB Reader Replacement
    1. Sony Xperia J SIM Card/Micro USB Reader Replacement, External Features: step 1, image 1 of 1
      • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
      Ask FixBot
    2. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 2, image 1 of 1
      • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
      Ask FixBot
    3. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
      Ask FixBot
    4. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 4, image 1 of 3 Sony Xperia J SIM Card/Micro USB Reader Replacement: step 4, image 2 of 3 Sony Xperia J SIM Card/Micro USB Reader Replacement: step 4, image 3 of 3
      • Using the Torx T5 screwdriver remove the four 4.74mm screws.
      • Then remove the two 3.13mm screws
      • Lastly remove 5.90mm screw.
      Ask FixBot
    5. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 5, image 1 of 3 Sony Xperia J SIM Card/Micro USB Reader Replacement: step 5, image 2 of 3 Sony Xperia J SIM Card/Micro USB Reader Replacement: step 5, image 3 of 3
      • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
      • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
      Ask FixBot
    6. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 6, image 1 of 1
      • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
      Ask FixBot
    7. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 7, image 1 of 1
      • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
      Ask FixBot
    1. Sony Xperia J SIM Card/Micro USB Reader Replacement, Removing parts: step 8, image 1 of 1
      Buy
      • Using the tweezers remove the clip located at the top of the phone. It should snap right off without too much pressure.
      Ask FixBot
    2. Sony Xperia J SIM Card/Micro USB Reader Replacement: step 9, image 1 of 1
      • Then remove the sticky pad located at the left of the phone using he tweezers.
      Ask FixBot
    3. Sony Xperia J SIM Card/Micro USB Reader Replacement, Removing Parts: step 10, image 1 of 2 Sony Xperia J SIM Card/Micro USB Reader Replacement, Removing Parts: step 10, image 2 of 2
      • Using the tweezers lift the plate out of the clamps, from left to right.
      • Then remove the whole plate off the phone.
      Ask FixBot
5 other people completed this guide.
Arlind
899 Reputation
5 Guides authored
USF Tampa, Team 4-3, Brown Winter 2015 Member of USF Tampa, Team 4-3, Brown Winter 2015
USFT-BROWN-W15S4G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 107
All Time: 3,323
