Up to 20% off select tools
Sony Xperia J Keyboard Module Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
91
All Time:
1,409
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
To complete this guide you will need to open the phone following the steps below to replace your keyboard module, using the required tools.
The battery should be removed before working on the phone internals.
    1. Sony Xperia J Keyboard Module Replacement, External Features: step 1, image 1 of 1
      • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
      Ask FixBot
    2. Sony Xperia J Keyboard Module Replacement: step 2, image 1 of 1
      • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
      Ask FixBot
    3. Sony Xperia J Keyboard Module Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
      Ask FixBot
    4. Sony Xperia J Keyboard Module Replacement: step 4, image 1 of 3 Sony Xperia J Keyboard Module Replacement: step 4, image 2 of 3 Sony Xperia J Keyboard Module Replacement: step 4, image 3 of 3
      • Using the Torx T5 screwdriver remove the four 4.74mm screws.
      • Then remove the two 3.13mm screws
      • Lastly remove 5.90mm screw.
      Ask FixBot
    5. Sony Xperia J Keyboard Module Replacement: step 5, image 1 of 3 Sony Xperia J Keyboard Module Replacement: step 5, image 2 of 3 Sony Xperia J Keyboard Module Replacement: step 5, image 3 of 3
      • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
      • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
      Ask FixBot
    6. Sony Xperia J Keyboard Module Replacement: step 6, image 1 of 1
      • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
      Ask FixBot
    7. Sony Xperia J Keyboard Module Replacement: step 7, image 1 of 1
      • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
      Ask FixBot
    1. Sony Xperia J Keyboard Module Replacement, Removing Parts: step 8, image 1 of 2 Sony Xperia J Keyboard Module Replacement, Removing Parts: step 8, image 2 of 2
      • Remove adhesive black tape at the bottom left of the phone.
      • Then remove the clip by pulling it up and slide out the wide orange cable(seen in picture 2).
      Ask FixBot
    2. Sony Xperia J Keyboard Module Replacement, Removing Parts: step 9, image 1 of 1
      Buy
      • By using the tweezers, unclip the cable at the bottom right by pulling it up.
      Ask FixBot
    3. Sony Xperia J Keyboard Module Replacement, Removing Parts: step 10, image 1 of 1
      • Finally, remove the keyboard module by pulling it up with the tweezers from right to left.
      Ask FixBot
2 other people completed this guide.
Author
with
Arlind
899 Reputation
5 Guides authored
USF Tampa, Team 4-3, Brown Winter 2015 Member of USF Tampa, Team 4-3, Brown Winter 2015
USFT-BROWN-W15S4G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 91
All Time: 1,409
