Sony Xperia E4 Logic Board Replacement
Video Overview
    1. Sony Xperia E4 Logic Board Replacement, Battery Cover: step 1, image 1 of 3 Sony Xperia E4 Logic Board Replacement, Battery Cover: step 1, image 2 of 3 Sony Xperia E4 Logic Board Replacement, Battery Cover: step 1, image 3 of 3
      • Remove the back cover and any installed SIM and memory cards.
      • There are 8x black screws Torx T4. Remove them.
      Ask FixBot
    2. Sony Xperia E4 Logic Board Replacement: step 2, image 1 of 3 Sony Xperia E4 Logic Board Replacement: step 2, image 2 of 3 Sony Xperia E4 Logic Board Replacement: step 2, image 3 of 3
      • Remove the small black rubber at the lower left corner.
      • Under it is the battery flex cable, disconnect it.
      Ask FixBot
    3. Sony Xperia E4 Logic Board Replacement: step 3, image 1 of 3 Sony Xperia E4 Logic Board Replacement: step 3, image 2 of 3 Sony Xperia E4 Logic Board Replacement: step 3, image 3 of 3
      • Use a plastic tool to separate the middle frame.
      • The battery is glued to the middle frame with an adhesive tape.
      • Loudspeaker
      Ask FixBot
    1. Sony Xperia E4 Logic Board Replacement, Logic Board: step 4, image 1 of 3 Sony Xperia E4 Logic Board Replacement, Logic Board: step 4, image 2 of 3 Sony Xperia E4 Logic Board Replacement, Logic Board: step 4, image 3 of 3
      • Disconnect the touch screen flex cable.
      • Under it is the LCD flex cable. Disconnect it also.
      Ask FixBot
    2. Sony Xperia E4 Logic Board Replacement: step 5, image 1 of 3 Sony Xperia E4 Logic Board Replacement: step 5, image 2 of 3 Sony Xperia E4 Logic Board Replacement: step 5, image 3 of 3
      • Remove the logic board.
      • Be careful for the flex cables.
      Ask FixBot
7 other people completed this guide.
ZFix
197,561 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
334 Members
8,250 Guides authored
1 Guide Comment
Anh ơi điện thoại của em ko vào đc mà hình chính nó hiện logo sony xong ko vào đc màn hình chính
Anh Nguyen - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 2,952
