Sony Xperia E - Password Removal Firmware Update
Video Overview
    1. Sony Xperia E - Password Removal  Firmware Update, Sony Xperia E - Password Removal  Firmware Update: step 1, image 1 of 2 Sony Xperia E - Password Removal  Firmware Update, Sony Xperia E - Password Removal  Firmware Update: step 1, image 2 of 2
      • First you can try to enter into the phone menu with your Google account, registered from before on this phone.
      • Your must be in range of WiFi network, used before with this phone.
      Ask FixBot
    2. Sony Xperia E - Password Removal  Firmware Update: step 2, image 1 of 3 Sony Xperia E - Password Removal  Firmware Update: step 2, image 2 of 3 Sony Xperia E - Password Removal  Firmware Update: step 2, image 3 of 3
      Ask FixBot
    3. Sony Xperia E - Password Removal  Firmware Update: step 3, image 1 of 2 Sony Xperia E - Password Removal  Firmware Update: step 3, image 2 of 2
      • Install Sony PC Companion in your PC.
      Ask FixBot
    4. Sony Xperia E - Password Removal  Firmware Update: step 4, image 1 of 3 Sony Xperia E - Password Removal  Firmware Update: step 4, image 2 of 3 Sony Xperia E - Password Removal  Firmware Update: step 4, image 3 of 3
      • From here you can update your firmware, but when you connect the phone, it must be switched on and not in security or password screen.
      • We will start "Support Zone" because from here we can flash the phone from switched off state regardless of whether there is a password.
      • Now start "Phone / Tablet Software Update".
      Ask FixBot
    5. Sony Xperia E - Password Removal  Firmware Update: step 5, image 1 of 3 Sony Xperia E - Password Removal  Firmware Update: step 5, image 2 of 3 Sony Xperia E - Password Removal  Firmware Update: step 5, image 3 of 3
      • Connect your laptop to power supply since the update of your phone will take some time.
      • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
      • This is your last warning about losing your personal data.
      Ask FixBot
    6. Sony Xperia E - Password Removal  Firmware Update: step 6, image 1 of 2 Sony Xperia E - Password Removal  Firmware Update: step 6, image 2 of 2
      • PC Companion will download some files to prepare your PC for software update
      • Your phone must be at last 80% for the update to proceed safely!
      Ask FixBot
    7. Sony Xperia E - Password Removal  Firmware Update: step 7, image 1 of 2 Sony Xperia E - Password Removal  Firmware Update: step 7, image 2 of 2
      • Select the model of your phone.
      • You should not confuse the model.
      Ask FixBot
    8. Sony Xperia E - Password Removal  Firmware Update: step 8, image 1 of 3 Sony Xperia E - Password Removal  Firmware Update: step 8, image 2 of 3 Sony Xperia E - Password Removal  Firmware Update: step 8, image 3 of 3
      • The USB cable must be connected only to the PC.
      • Turn off the phone.
      • Press and hold the Volume Down button while plugging the cable into your phone.
      • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
      Ask FixBot
    9. Sony Xperia E - Password Removal  Firmware Update: step 9, image 1 of 3 Sony Xperia E - Password Removal  Firmware Update: step 9, image 2 of 3 Sony Xperia E - Password Removal  Firmware Update: step 9, image 3 of 3
      • Your PC must recognize your phone like SOMC Flash Device.
      • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
      • Android WinUSB drivers
      Ask FixBot
    10. Sony Xperia E - Password Removal  Firmware Update: step 10, image 1 of 2 Sony Xperia E - Password Removal  Firmware Update: step 10, image 2 of 2
      • When PC Companion finished with update process, disconnect the phone and switch it on.
      Ask FixBot
    11. Sony Xperia E - Password Removal  Firmware Update: step 11, image 1 of 2 Sony Xperia E - Password Removal  Firmware Update: step 11, image 2 of 2
      • Now your phone is in factory condition, with erased custom data, without password protection and with the last firmware, available for the model.
      • Did you do it successfully?
      • Please SUBSCRIBE to my channel ツ
      Ask FixBot
11 other people completed this guide.
ZFix
197,699 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
2 Guide Comments
Downloaded the application but it wants a Administrator password..... is there an another way to download this application?
Althea Kruger - Reply Share
My sony Xperia c1605 is deny pasword am using for it pls anyvody to help me out what can i do
Aweda Kabeer - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 140
All Time: 30,045
