Sony Xperia 10 VI Screen Replacement
    1. Sony Xperia 10 VI Screen Replacement, Screen Replacement: step 1, image 1 of 1
      • Replacing the screen on this mobile is quite involved. You have to detach the screen and also to open the backside to get to the connector.
      Ask FixBot
    2. Sony Xperia 10 VI Screen Replacement, Remove Back Cover: step 2, image 1 of 1
      • To remove the back cover, you have to do the usual: heating with a heat gun and then pry it open with opening picks.
      Ask FixBot
    3. Sony Xperia 10 VI Screen Replacement, Detach Screen: step 3, image 1 of 1
      • As a next step, heat evenly along the side of the screen with the heat gun. Pry open carefully from the bottom where the microphone is located, as all the other sides are too tight to get into. Be careful with the screen connector, this is attached to the screen on the bottom right when looked at from above. It cannot be disconnected at this step.
      Ask FixBot
    4. Sony Xperia 10 VI Screen Replacement, Remove Screen Connector: step 4, image 1 of 1
      • Remove the six screws which hold the charge cover using a PH000 screwdriver.
      Ask FixBot
    5. Sony Xperia 10 VI Screen Replacement, Remove the Charger Board: step 5, image 1 of 1
      • As the charger board overlaps the screen connector, it needs to be removed. For this, you'll need to disconnect the cable press connector and the two flex cable connectors.
      Ask FixBot
    6. Sony Xperia 10 VI Screen Replacement, Detach Screen: step 6, image 1 of 1
      • With the charger board (grey) removed, you are able to detach the screen from the press cable connector.
      Ask FixBot
    7. Sony Xperia 10 VI Screen Replacement, New Screen and Re-Assemblement: step 7, image 1 of 1
      • Now attach the new screen, reassemble (use suitable glue for screen and backcover) and enjoy.
      Ask FixBot
2 other people completed this guide.
Romax
364 Reputation
2 Guides authored
1 Guide Comment
Just changed the display, in my case removal of the small PCB (marked grey) was not needed. In my case there was enough space to carefully remove the connector and connect the new one.
Marceline Hauser - Reply Share
Past 24 Hours: 4
Past 7 Days: 53
Past 30 Days: 226
All Time: 1,584
