Up to 20% off select tools
Sony XPERIA Tablet Z Volume Button Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
91
All Time:
3,099
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: step 1, image 1 of 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: step 1, image 2 of 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
      • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
      • Remove cover
      • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
      Ask FixBot
    2. Sony XPERIA Tablet Z Volume Button Replacement, Locate the Volume module: step 2, image 1 of 1
      • Locate the volume module.
      • Remove both screws using the Philips screwdriver.
      Ask FixBot
    3. Sony XPERIA Tablet Z Volume Button Replacement, Lift out of Place: step 3, image 1 of 1
      • Once both screws are removed grab the tweezers.
      • Then lift up on the module.
      Ask FixBot
    4. Sony XPERIA Tablet Z Volume Button Replacement, Removing the Electrical tape: step 4, image 1 of 1
      • Find the electrical tape connecting the module to the motherboard
      • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
      Ask FixBot
Author
with
Martin Luna
1,873 Reputation
5 Guides authored
USF Tampa, Team 15-6, Remmell Fall 2014 Member of USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 91
All Time: 3,099
