Sony XPERIA Tablet Z Screen Replacement
    1. Sony XPERIA Tablet Z Screen Replacement, Screen: step 1, image 1 of 3 Sony XPERIA Tablet Z Screen Replacement, Screen: step 1, image 2 of 3 Sony XPERIA Tablet Z Screen Replacement, Screen: step 1, image 3 of 3
      • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
      Ask FixBot
    2. Sony XPERIA Tablet Z Screen Replacement: step 2, image 1 of 3 Sony XPERIA Tablet Z Screen Replacement: step 2, image 2 of 3 Sony XPERIA Tablet Z Screen Replacement: step 2, image 3 of 3
      • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
      • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
      Ask FixBot
    3. Sony XPERIA Tablet Z Screen Replacement: step 3, image 1 of 1
      • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
      • Only heat enough to loosen the adhesive but not damage the tablet.
      Ask FixBot
    4. Sony XPERIA Tablet Z Screen Replacement: step 4, image 1 of 1
      • Gently pry the edge of the screen working around while heating.
      Ask FixBot
    5. Sony XPERIA Tablet Z Screen Replacement: step 5, image 1 of 1
      • Clean adhesive from perimeter of frame to prepare for new screen.
      Ask FixBot
8 other people completed this guide.
Gustavo Correa
373 Reputation
1 Guide authored
IUPUI, Team S5-G1, Harley Summer 2017 Member of IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Members
36 Guides authored
5 Guide Comments
اريدشراءاريدشراءشاشه جديده
kore ares - Reply Share
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Reply Share
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Reply Share
Wooo its self explanatory.Good work
Duncan Mwaniki - Reply Share
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 29
All Time: 8,392
