Sony XDR-S50 DAB Radio Button Replacement
  1. Sony XDR-S50 DAB Radio Button Replacement, Opening the case: step 1, image 1 of 2 Sony XDR-S50 DAB Radio Button Replacement, Opening the case: step 1, image 2 of 2
    • Remove the batteries.
    • Remove 4 cross-head screws from the rear of the case and a fifth in the battery compartment.
    • The back should now lift off.
    • A wire is still connecting the aerial to the main circuit board. Do not strain it unduly.
    Ask FixBot
  2. Sony XDR-S50 DAB Radio Button Replacement, Disconnecting the aerial: step 2, image 1 of 2 Sony XDR-S50 DAB Radio Button Replacement, Disconnecting the aerial: step 2, image 2 of 2
    • Remove the aerial retaining screw.
    • Lift the aerial slightly in order to release the aerial connecting tag. You can now put the case rear cover aside.
    Ask FixBot
  3. Sony XDR-S50 DAB Radio Button Replacement, Removing the knobs: step 3, image 1 of 2 Sony XDR-S50 DAB Radio Button Replacement, Removing the knobs: step 3, image 2 of 2
    • Pull off the volume knob.
    • To remove the tuning knob, gently prise it off with a jimmy.
    • Under the tuning knob you will see a spring. Note its position for reassembly and remove it, taking care it doesn't take flight.
    Ask FixBot
  4. Sony XDR-S50 DAB Radio Button Replacement, Releasing the midframe: step 4, image 1 of 1
    • Unsolder the two wires connecting to the loud speaker. (This is not essential but will save you from straining these wires.)
    • Remove 2 screws from the grey midframe, one on the lower right on the battey connector and the other on the upper left above the tuning knob.
    • Release the two cables from their retaining clips under the battery compartment.
    Ask FixBot
  5. Sony XDR-S50 DAB Radio Button Replacement, Removing the midframe: step 5, image 1 of 1
    • Lift the grey battery connector slightly to disengage a bush where you removed a screw in the previous step. (On reassembly, ensure this is snapped back in place.)
    • Ease the power and headphone sockets out of their holes in the case, using a spudger or similar tool.
    • You can now lift the midframe and attached assemblies out of the case, first lifting the right hand side by the power and headphone sockets, and hence withdrawing the volume and tuning spindles from the left hand side.
    • Before reassembly it's worth dusting the LCD display and the inside of the display window.
    Ask FixBot
  6. Sony XDR-S50 DAB Radio Button Replacement, Buttons board removal: step 6, image 1 of 2 Sony XDR-S50 DAB Radio Button Replacement, Buttons board removal: step 6, image 2 of 2
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Remove two screws holding the buttons board to the midframe.
    • Lift the buttons board from the power button end, and release the other end from beneath a retaining tab.
    • On reassembly, ensure that the right hand end of the buttons board is correctly located under the tab, otherwise the assembly will not fit back in the case.
    • If required, you can now unsolder and replace any of the buttons. For this, a desoldering pump is most effective.
    • Replacement 6x6mm tactile buttons are widely available in a range of heights. The 5mm height should fit, but lay a ruler along the tops of all the buttons to check the height before soldering a replacement.
    Ask FixBot
2 other people completed this guide.
Philip Le Riche
32,564 Reputation
48 Guides authored
Restart Project Member of Restart Project
Local Repair Groups
29 Members
420 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 43
All Time: 1,238
