Sony XAV-AX100 Motherboard Replacement
    1. Sony XAV-AX100 Motherboard Replacement, USB Cable: step 1, image 1 of 3 Sony XAV-AX100 Motherboard Replacement, USB Cable: step 1, image 2 of 3 Sony XAV-AX100 Motherboard Replacement, USB Cable: step 1, image 3 of 3
      • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
      • Remove the ten 3.5mm Phillips #0 screws from the back plate.
      Ask FixBot
    2. Sony XAV-AX100 Motherboard Replacement: step 2, image 1 of 2 Sony XAV-AX100 Motherboard Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to remove the back plate.
      • Don't remove completely as there will still be cables connected.
      Ask FixBot
    3. Sony XAV-AX100 Motherboard Replacement: step 3, image 1 of 1
      • Disconnect the USB cable from the display board.
      Ask FixBot
    4. Sony XAV-AX100 Motherboard Replacement: step 4, image 1 of 1
      • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
      • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
      Ask FixBot
    5. Sony XAV-AX100 Motherboard Replacement: step 5, image 1 of 3 Sony XAV-AX100 Motherboard Replacement: step 5, image 2 of 3 Sony XAV-AX100 Motherboard Replacement: step 5, image 3 of 3
      • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
      • Pull the USB cable off of the back plate.
      Ask FixBot
    1. Sony XAV-AX100 Motherboard Replacement, Motherboard: step 6, image 1 of 2 Sony XAV-AX100 Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Disconnect the display power cable from the motherboard.
      • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
      Ask FixBot
    2. Sony XAV-AX100 Motherboard Replacement: step 7, image 1 of 3 Sony XAV-AX100 Motherboard Replacement: step 7, image 2 of 3 Sony XAV-AX100 Motherboard Replacement: step 7, image 3 of 3
      • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
      • Use a spudger to gently lift the motherboard up and out of the radio.
      Ask FixBot
Abdulaziz Redha
741 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Cagle Spring 2018 Member of USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Members
60 Guides authored
2 Guide Comments
Where to buy the motherboard ?
B.Keat - Reply Share
Where to buy sony xav-ax5000 motherboard
Smoitez Fanai - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 2,249
