Sony Walkman WM-AF48 Power Switch Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
107
All Time:
2,741
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your Walkman will not turn on and you are certain that the batteries are new or fully charged, you may need to replace the device's power switch. To do so, you will need a spudger and soldering iron.
Tools
    1. Sony Walkman WM-AF48 Power Switch Replacement, Getting started: step 1, image 1 of 1
      • Remove any batteries or cassettes from the Walkman.
      Ask FixBot
    2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: step 2, image 1 of 3 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: step 2, image 2 of 3 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: step 2, image 3 of 3
      • Using a spudger, separate the back cover from the front.
      • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
      Ask FixBot
    1. Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: step 3, image 1 of 2 Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: step 3, image 2 of 2
      • Gently pull the ribbon from the jack above the film revolver, near the edge.
      • Lift the motherboard from the outer shell.
      • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
      Ask FixBot
    2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the power switch: step 4, image 1 of 1
      • Identify the six points where the power switch is soldered to the motherboard.
      • Using a soldering iron, remove the switch by de-soldering these points which hold it in place.
      Ask FixBot
Wilson Riforgiat
931 Reputation
4 Guides authored
1 Guide Comment
Hi,
Where would you find a Vintage Sports Sony Walkman power switch ? Battery light is on one function and then turns off on the other. Other than this, the unit is in EXCELLENT Condition. THANKS for any insight and for helping us :)
Pamela Osborne - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 107
All Time: 2,741
