Sony Walkman WM-AF48 Outer Cover Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
73
All Time:
2,343
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replace a broken outer cover on your Sony Walkman WM-AF48.
Tools
  • Spudger
    4.9
    1. Sony Walkman WM-AF48 Outer Cover Replacement, Getting started: step 1, image 1 of 1
      • Remove any batteries or cassettes from the Walkman.
      Ask FixBot
    2. Sony Walkman WM-AF48 Outer Cover Replacement, Remove the outer cover: step 2, image 1 of 3 Sony Walkman WM-AF48 Outer Cover Replacement, Remove the outer cover: step 2, image 2 of 3 Sony Walkman WM-AF48 Outer Cover Replacement, Remove the outer cover: step 2, image 3 of 3
      • Using a spudger, separate the back cover from the front.
      • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
      Ask FixBot
2 other people completed this guide.
Wilson Riforgiat
931 Reputation
4 Guides authored
1 Guide Comment
There are four tabs on the WM-AF48 Model inside the door and around the body that are made to release the back cover.
Ethan Jones - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 73
All Time: 2,343
