Sony Walkman WM-AF48 Headphone Jack Replacement
  1. Sony Walkman WM-AF48 Headphone Jack Replacement, Getting started: step 1, image 1 of 1
    • Remove any batteries or cassettes from the Walkman.
    Ask FixBot
  2. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: step 2, image 1 of 3 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: step 2, image 2 of 3 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: step 2, image 3 of 3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
    Ask FixBot
  3. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the motherboard: step 3, image 1 of 2 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the motherboard: step 3, image 2 of 2
    • Gently pull the ribbon from the jack just above the film revolver, near the edge.
    • Carefully lift the motherboard out of the outer shell.
    • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
    Ask FixBot
  4. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the headphone jack: step 4, image 1 of 1
    • Locate the four metal points on the motherboard that hold the headphone jack in place.
    • Using a soldering iron, remove the headphone jack by de-soldering the four points that hold it in place.
    Ask FixBot
7 other people completed this guide.
Wilson Riforgiat
931 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 68
All Time: 6,182
