Up to 20% off select tools
Sony Walkman NWZ-E438 Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
112
All Time:
1,412
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a cracked or broken screen on you Sony Walkman NWZ-E438.
    1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: step 1, image 1 of 1
      • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
      • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
      Ask FixBot
    2. Sony Walkman NWZ-E438 Screen  Replacement: step 2, image 1 of 1
      • Use a small prying tool to carefully pry open the back of the device.
      Ask FixBot
    1. Sony Walkman NWZ-E438 Screen  Replacement, Screen: step 3, image 1 of 1
      • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
      Ask FixBot
    2. Sony Walkman NWZ-E438 Screen  Replacement: step 4, image 1 of 1
      • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
      • Slowly circle the device, popping the outside of the frame off.
      Ask FixBot
    3. Sony Walkman NWZ-E438 Screen  Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
      Ask FixBot
    4. Sony Walkman NWZ-E438 Screen  Replacement: step 6, image 1 of 1
      • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
      Ask FixBot
    5. Sony Walkman NWZ-E438 Screen  Replacement: step 7, image 1 of 1
      • The screen will be removed.
      Ask FixBot
Author
with
Cheryl Zinn
525 Reputation
5 Guides authored
1 Guide Comment
wher buy display
Pavel Drobny - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 112
All Time: 1,412
