Sony Walkman D-E356CK Disk Motor Replacement
  1. Sony Walkman D-E356CK Disk Motor Replacement, Back Panel: step 1, image 1 of 1
    • Open the battery compartment.
    • Remove the AA batteries from within the compartment.
    Ask FixBot
  2. Sony Walkman D-E356CK Disk Motor Replacement: step 2, image 1 of 3 Sony Walkman D-E356CK Disk Motor Replacement: step 2, image 2 of 3 Sony Walkman D-E356CK Disk Motor Replacement: step 2, image 3 of 3
    • Press the button located in the bottom left corner of the device labeled "open."
    • Remove the three 11 mm-long Phillips screws.
    Ask FixBot
  3. Sony Walkman D-E356CK Disk Motor Replacement: step 3, image 1 of 2 Sony Walkman D-E356CK Disk Motor Replacement: step 3, image 2 of 2
    • Remove the two 11 mm-long Phillips screws on the back side of the Walkman.
    Ask FixBot
  4. Sony Walkman D-E356CK Disk Motor Replacement: step 4, image 1 of 2 Sony Walkman D-E356CK Disk Motor Replacement: step 4, image 2 of 2
    • Insert an opening tool into the seam between the back panel and chassis.
    • Pry around the perimeter until the back panel releases.
    • Remove the back panel.
    Ask FixBot
  5. Sony Walkman D-E356CK Disk Motor Replacement, Motherboard: step 5, image 1 of 3 Sony Walkman D-E356CK Disk Motor Replacement, Motherboard: step 5, image 2 of 3 Sony Walkman D-E356CK Disk Motor Replacement, Motherboard: step 5, image 3 of 3
    • Gently lift the motherboard to reveal the backside of the motherboard.
    • Disconnect the two JST connectors.
    Ask FixBot
  6. Sony Walkman D-E356CK Disk Motor Replacement: step 6, image 1 of 1
    • Lift the latch that secures the ribbon cable.
    • Disconnect the ribbon cable.
    Ask FixBot
  7. Sony Walkman D-E356CK Disk Motor Replacement, Disk Motor: step 7, image 1 of 3 Sony Walkman D-E356CK Disk Motor Replacement, Disk Motor: step 7, image 2 of 3 Sony Walkman D-E356CK Disk Motor Replacement, Disk Motor: step 7, image 3 of 3
    • Remove the disk motor housing from front panel and flip it over.
    • Remove the 5mm screws from the disk motor.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andrew Choquette
366 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-1, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 110
