Sony Walkman A-45 Battery Replacement
  1. Sony Walkman A-45 Battery Replacement, Battery Replacement: step 1, image 1 of 1
    • Turn on your Walkman and allow the battery to discharge below 5% before starting any repairs, as a charged Lithium Battery can be dangerous if accidentally punctured.
    • Turn off the device.
    Ask FixBot
  2. Sony Walkman A-45 Battery Replacement: step 2, image 1 of 3 Sony Walkman A-45 Battery Replacement: step 2, image 2 of 3 Sony Walkman A-45 Battery Replacement: step 2, image 3 of 3
    • Insert a Jimmy into the thin gap between the shell and the side of the top cover, along the edge of one of the panels.
    • Pry up on the top cover to release it from the adhesive.
    • Once the adhesive doesn't stick from one edge, the rest disconnects easily. It will take a couple tries.
    Ask FixBot
  3. Sony Walkman A-45 Battery Replacement: step 3, image 1 of 3 Sony Walkman A-45 Battery Replacement: step 3, image 2 of 3 Sony Walkman A-45 Battery Replacement: step 3, image 3 of 3
    • Insert a Jimmy into the thin gap between the shell and the side of the bottom cover, along the edge of one of the panels.
    • Pry up on the bottom cover to release it from the adhesive.
    Ask FixBot
  4. Sony Walkman A-45 Battery Replacement: step 4, image 1 of 2 Sony Walkman A-45 Battery Replacement: step 4, image 2 of 2
    • Remove the two bottom screws holding the chassis using a Phillips #00 screwdriver.
    Ask FixBot
  5. Sony Walkman A-45 Battery Replacement: step 5, image 1 of 3 Sony Walkman A-45 Battery Replacement: step 5, image 2 of 3 Sony Walkman A-45 Battery Replacement: step 5, image 3 of 3
    • Flip the walkman on its screen.
    • Insert a Jimmy into the thin gap between the side panel and shell, along the edge of the panel.
    • Slowly pry up the back cover to release it from its adhesive.
    • If you have difficulty keeping the gap up, insert opening picks to prop it open.
    Ask FixBot
  6. Sony Walkman A-45 Battery Replacement: step 6, image 1 of 3 Sony Walkman A-45 Battery Replacement: step 6, image 2 of 3 Sony Walkman A-45 Battery Replacement: step 6, image 3 of 3
    • Remove the five screws holding down the battery and NFC Module using a Phillips #00 screwdriver.
    • Detach the ribbon cable connecting the NFC Module by pulling outward.
    • Don't pull too hard or else the ribbon cable will rip.
    Ask FixBot
  7. Sony Walkman A-45 Battery Replacement, Remove the Battery: step 7, image 1 of 3 Sony Walkman A-45 Battery Replacement, Remove the Battery: step 7, image 2 of 3 Sony Walkman A-45 Battery Replacement, Remove the Battery: step 7, image 3 of 3
    • Lift up the metal chassis carefully.
    • There will be a block piece which holds the wires. Pull it up carefully and it should come off.
    Ask FixBot
  8. Sony Walkman A-45 Battery Replacement: step 8, image 1 of 3 Sony Walkman A-45 Battery Replacement: step 8, image 2 of 3 Sony Walkman A-45 Battery Replacement: step 8, image 3 of 3
    • Heat a soldering iron to 420 degrees Celsius.
    • Heat up the old solder in the Walkman and remove the wire from its terminal.
    • This process will take time to remove the wires.
    Ask FixBot
  9. Sony Walkman A-45 Battery Replacement: step 9, image 1 of 1
    • Loosen the battery adhesive by using isopropyl alcohol.
    • Use Isopropyl Alcohol 90% or greater.
    • Pry out the battery using plastic cards.
    • Make sure to NOT bend the battery, Take your time during this process.
    • Remove the battery.
    Ask FixBot
3 other people completed this guide.
Edwin Ruiz
250 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 238
All Time: 3,227
