Sony WH-CH720N Speaker Replacement
  1. Sony WH-CH720N Speaker Replacement, Ear Pad: step 1, image 1 of 1
    • Place the headphones down on a table, and orient them in this way.
    Ask FixBot
  2. Sony WH-CH720N Speaker Replacement: step 2, image 1 of 3 Sony WH-CH720N Speaker Replacement: step 2, image 2 of 3 Sony WH-CH720N Speaker Replacement: step 2, image 3 of 3
    • Remove the ear pad.
    • Check introductions to ensure you remove the correct side earmuff for each repair guide!
    Ask FixBot
  3. Sony WH-CH720N Speaker Replacement, Speaker: step 3, image 1 of 2 Sony WH-CH720N Speaker Replacement, Speaker: step 3, image 2 of 2
    • Remove the four 5 mm screws holding the speaker housing onto the headphones.
    • Move the now detached speaker housing to the side, being careful of the wires.
    Ask FixBot
  4. Sony WH-CH720N Speaker Replacement: step 4, image 1 of 2 Sony WH-CH720N Speaker Replacement: step 4, image 2 of 2
    • On the backside of the speaker housing, remove the four 3 mm screws to detach the panel.
    Ask FixBot
  5. Sony WH-CH720N Speaker Replacement: step 5, image 1 of 3 Sony WH-CH720N Speaker Replacement: step 5, image 2 of 3 Sony WH-CH720N Speaker Replacement: step 5, image 3 of 3
    • With the speaker panel removed, desolder the wires connecting the speaker.
    • Use a heat gun to loosen the glue around the speaker inside the housing.
    • Finally, take the metal prying tool, and carefully remove the speaker.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 98
All Time: 1,983
