Sony WH-CH720N Charging Port Replacement
  1. Sony WH-CH720N Charging Port Replacement, Ear Pad: step 1, image 1 of 1
    • Place the headphones down on a table, and orient them in this way.
    Ask FixBot
  2. Sony WH-CH720N Charging Port Replacement: step 2, image 1 of 3 Sony WH-CH720N Charging Port Replacement: step 2, image 2 of 3 Sony WH-CH720N Charging Port Replacement: step 2, image 3 of 3
    • Remove the ear pad.
    • Check introductions to ensure you remove the correct side earmuff for each repair guide!
    Ask FixBot
  3. Sony WH-CH720N Charging Port Replacement, Charging Port: step 3, image 1 of 2 Sony WH-CH720N Charging Port Replacement, Charging Port: step 3, image 2 of 2
    • Use a Philips #00 screwdriver to remove the four 5 mm screws from the left driver housing.
    Ask FixBot
  4. Sony WH-CH720N Charging Port Replacement: step 4, image 1 of 3 Sony WH-CH720N Charging Port Replacement: step 4, image 2 of 3 Sony WH-CH720N Charging Port Replacement: step 4, image 3 of 3
    • Using the same bit, remove the two 3 mm screws from the circuit board.
    • Gently remove the circuit board.
    Ask FixBot
  5. Sony WH-CH720N Charging Port Replacement: step 5, image 1 of 1
    • Desolder the four joints holding the USB-C charging port there.
    • Pull the charging port off.
    Ask FixBot
    • Solder the new charging port onto the board.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 77
All Time: 1,377
