Sony WH-CH720N Battery Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
10
Past 7 Days:
54
Past 30 Days:
269
All Time:
6,294
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide will help you learn how to locate, remove, and replace the battery for the Sony WH-CH720N. The battery is in the right side of the headphones. This is necessary in the event the headphones stop accepting a charge or refuse to power on despite charging.
DO NOT puncture the battery, as it might explode. Dispose of the battery in the proper receptacle.
Tools
    1. Sony WH-CH720N Battery Replacement, Ear Pad: step 1, image 1 of 1
      • Place the headphones down on a table, and orient them in this way.
      Ask FixBot
    2. Sony WH-CH720N Battery Replacement: step 2, image 1 of 3 Sony WH-CH720N Battery Replacement: step 2, image 2 of 3 Sony WH-CH720N Battery Replacement: step 2, image 3 of 3
      • Remove the ear pad.
      • Check introductions to ensure you remove the correct side earmuff for each repair guide!
      Ask FixBot
    1. Sony WH-CH720N Battery Replacement, Battery: step 3, image 1 of 3 Sony WH-CH720N Battery Replacement, Battery: step 3, image 2 of 3 Sony WH-CH720N Battery Replacement, Battery: step 3, image 3 of 3
      • Remove the four 5 mm screws in the right using a Phillips #00 screwdriver.
      • Remove the speaker panel to reveal the battery.
      Ask FixBot
    2. Sony WH-CH720N Battery Replacement: step 4, image 1 of 2 Sony WH-CH720N Battery Replacement: step 4, image 2 of 2
      • Unplug the battery with tweezers
      Ask FixBot
    3. Sony WH-CH720N Battery Replacement: step 5, image 1 of 3 Sony WH-CH720N Battery Replacement: step 5, image 2 of 3 Sony WH-CH720N Battery Replacement: step 5, image 3 of 3
      • Gently remove the battery from the device using the plastic spudger.
      Ask FixBot
5 other people completed this guide.
1 Guide Comment
Followed this, and all good, thank you. The wires attaching the speaker to the board are very thin and not very long, so super caution needed. Replacement battery was 15 Euro, and was advertised as for 1000MX4 charging case, but fitted and works perfectly. Insane that you have to take the thing apart just to replace the battery though...
Graham Monro - Reply Share
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 269
All Time: 6,294
