Sony WH-CH520 USB-C Charging Port Replacement
  1. Sony WH-CH520 USB-C Charging Port Replacement, Earpad Cushion: step 1, image 1 of 1
    • Hold the headphones in one hand, and with your other hand lightly pinch the earpad cushion.
    Ask FixBot
  2. Sony WH-CH520 USB-C Charging Port Replacement: step 2, image 1 of 3 Sony WH-CH520 USB-C Charging Port Replacement: step 2, image 2 of 3 Sony WH-CH520 USB-C Charging Port Replacement: step 2, image 3 of 3
    • Pull the pinched portion of the cushion up and towards yourself.
    • Pull part of the cushion off of the lip of the headphones.
    • Fully remove by pulling the earpad cushion down and away from yourself.
    Ask FixBot
  3. Sony WH-CH520 USB-C Charging Port Replacement, USB-C Charging Port: step 3, image 1 of 2 Sony WH-CH520 USB-C Charging Port Replacement, USB-C Charging Port: step 3, image 2 of 2
    • Remove the three 2.5 mm screws from the right side of the headphones using a JIS #00 screwdriver.
    Ask FixBot
  4. Sony WH-CH520 USB-C Charging Port Replacement: step 4, image 1 of 3 Sony WH-CH520 USB-C Charging Port Replacement: step 4, image 2 of 3 Sony WH-CH520 USB-C Charging Port Replacement: step 4, image 3 of 3
    • Place one end of an opening tool against the edge of the base with the hook-like side pushing up against the covering.
    • Carefully pull the tool down against the edge to lift the covering.
    • Move the tool to different spots around the base of the headphones to pry it up until the covering comes off.
    Ask FixBot
  5. Sony WH-CH520 USB-C Charging Port Replacement: step 5, image 1 of 2 Sony WH-CH520 USB-C Charging Port Replacement: step 5, image 2 of 2
    • Carefully remove the film adhesive on top of the battery using a pair of tweezers.
    Ask FixBot
  6. Sony WH-CH520 USB-C Charging Port Replacement: step 6, image 1 of 2 Sony WH-CH520 USB-C Charging Port Replacement: step 6, image 2 of 2
    • Carefully pry the battery up and off of its adhesive using a spudger.
    • You can rest the battery in its well to prevent it from getting in the way later
    Ask FixBot
  7. Sony WH-CH520 USB-C Charging Port Replacement: step 7, image 1 of 2 Sony WH-CH520 USB-C Charging Port Replacement: step 7, image 2 of 2
    • Remove the 2.5 mm screw from the center of the motherboard using a Phillips #00 screwdriver.
    Ask FixBot
  8. Sony WH-CH520 USB-C Charging Port Replacement: step 8, image 1 of 2 Sony WH-CH520 USB-C Charging Port Replacement: step 8, image 2 of 2
    • Use the tweezers to pinch the silicone casing surrounding the microphone.
    • Pull it up and out from the headphone casing.
    Ask FixBot
  9. Sony WH-CH520 USB-C Charging Port Replacement: step 9, image 1 of 3 Sony WH-CH520 USB-C Charging Port Replacement: step 9, image 2 of 3 Sony WH-CH520 USB-C Charging Port Replacement: step 9, image 3 of 3
    • Use the opening tool to lift the motherboard out of the headphone casing.
    • Isolate all wires and electronic components from the plastic pieces.
    • Flip the motherboard such that the back pins of the charging port are exposed.
    Ask FixBot
  10. Sony WH-CH520 USB-C Charging Port Replacement: step 10, image 1 of 2 Sony WH-CH520 USB-C Charging Port Replacement: step 10, image 2 of 2
    • Heat your soldering iron to around 350-450°F (175°C-230°C).
    • Reheat the solder on each pin one by one.
    • After reheating, use the tweezers to pull up on the charging port, releasing each pin from its place.
    • The soldering iron and metal components will be HOT; use caution when handling.
    Ask FixBot
Emma Warn
231 Reputation
1 Guide authored
UMass Dartmouth, Team 2-2, Konn Fall 2024 Member of UMass Dartmouth, Team 2-2, Konn Fall 2024
UMASSD-KONN-F24S2G2
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 85
All Time: 985
