Introduction
This guide is intended to help you reattach a severed headphone on Sony WH-CH520 wireless headphones using a soldering iron.
Before reattaching your headphone, you should verify that the sound is still working and the connecting wire is free of physical damage. This guide includes soldering; take caution while working with a heated soldering iron and melting materials.
Plug in the soldering iron, allowing it time to heat to 480 degrees Fahrenheit.
2 Guide Comments
>Remove the ability for the head rotate
>Repair
This is more of a doing of your best with what you've got kinda fix
Also this is fixing the joint not the wire
Two great solutions that keep the ability to rotate the headset
Fixing the same hinge
https://www.youtube.com/watch?v=IsJWJjtS...
In-depth hinge replacement
