Introduction
Go to step 1 ↓Over time or with overuse, batteries can become corroded. If you notice the battery life decreasing significantly or possibly a strange smell coming from the Sony WH-CH520, it could mean it's time for a battery change. Replacing a battery requires being able to handle tools in small electronics and soldering experience.
Tools
Spudger4.9
Lay headphones flat against the surface with the ear cushions oriented upwards.
Pinch the cushion of the right labeled headphone near the edge of the device to carefully pull the cushion off.
Place one end of an opening tool against the edge of the base with the hook-like side pushing up against the covering.
Carefully pull the tool down against the edge to lift the covering.
Move the tool to different spots around the base of the headphones to pry it up until the covering comes off.
