Up to 20% off select tools
Sony WH-1000XM4 Touch Sensor Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
64
Past 30 Days:
231
All Time:
5,482
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the touch sensor on the Sony WH-1000XM4 wireless headphones.
Ensure the headphones are powered off and discharged.
As a precaution utilize the antistatic wrist strap to avoid damaging any of the electronic components.
    1. Sony WH-1000XM4 Touch Sensor Replacement, Touch Sensor: step 1, image 1 of 1
      • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
      • Place your headphones onto a work surface, ear pads facing up.
      Ask FixBot
    2. Sony WH-1000XM4 Touch Sensor Replacement: step 2, image 1 of 1
      • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
      • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
      • Pivot the spudger down to unclip the long edge of the ear pad.
      • Repeat around perimeter of ear pad until it is loose.
      • When the first clip disconnects, you'll hear an audible clicking sound.
      • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
      Ask FixBot
    3. Sony WH-1000XM4 Touch Sensor Replacement: step 3, image 1 of 1
      • Remove the right ear pad.
      Ask FixBot
    4. Sony WH-1000XM4 Touch Sensor Replacement: step 4, image 1 of 1
      • Remove the foam liner from the right ear cup's speaker.
      Ask FixBot
    5. Sony WH-1000XM4 Touch Sensor Replacement: step 5, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the right ear cup cover.
      Ask FixBot
    6. Sony WH-1000XM4 Touch Sensor Replacement: step 6, image 1 of 1
      • Flip the headphones over, ear cups facing down.
      • Use your fingers to lift up and flip over the right ear cup cover.
      • Don't try to completely remove the cover just yet—it's still attached with the touch cable.
      Ask FixBot
    7. Sony WH-1000XM4 Touch Sensor Replacement: step 7, image 1 of 1
      • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
      • Remove the ear cup cover with the touch sensor attached.
      • The green touch sensor circuit board is glued to the ear cup cover.
      • Repeat steps in reverse order to reassemble after replacing the touch sensor.
      Ask FixBot
Author
with
Spencer Decker
577 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Fall 2023 Member of IUPUI, Team 2-1, Harley Fall 2023
IUPUI-HARLEY-F23S2G1
3 Members
36 Guides authored
2 Guide Comments
Bonjour, le titre n'est pas bon, ce n'est pas le bon modèle, qui fait référence aux oreillettes sans fil
Brice - Reply Share
Guy it is for just WH-1000XM4 model.
51515 - Reply Share
Past 24 Hours: 6
Past 7 Days: 64
Past 30 Days: 231
All Time: 5,482
