Sony WH-1000XM4 Swivel Replacement
    1. Sony WH-1000XM4 Swivel Replacement, Right side, ear muff: step 1, image 1 of 3 Sony WH-1000XM4 Swivel Replacement, Right side, ear muff: step 1, image 2 of 3 Sony WH-1000XM4 Swivel Replacement, Right side, ear muff: step 1, image 3 of 3
      • Using an opening tool, pry off the right ear muff and remove the underlying foam.
      Ask FixBot
    2. Sony WH-1000XM4 Swivel Replacement, Right side, screws: step 2, image 1 of 1
      • Remove the four silver screws on right side of the headphones using a Phillips #000 screwdriver.
      Ask FixBot
    3. Sony WH-1000XM4 Swivel Replacement, Right side, cup cover: step 3, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Right side, cup cover: step 3, image 2 of 2
      • Flip the headphones.
      • Lift up and flip the right ear cup cover.
      • Don't try to completely remove the cover just yet—it's still attached with the touch cable.
      Ask FixBot
    4. Sony WH-1000XM4 Swivel Replacement, Right side, touch ribbon cable: step 4, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Right side, touch ribbon cable: step 4, image 2 of 2
      • Detach the ribbon cable connecting the backplate to the right ear.
      Ask FixBot
    5. Sony WH-1000XM4 Swivel Replacement, Right side, thermal sensor ribbon cable: step 5, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Right side, thermal sensor ribbon cable: step 5, image 2 of 2
      • Detach the yellow thermal sensor ribbon cable from the motherboard.
      Ask FixBot
    6. Sony WH-1000XM4 Swivel Replacement, Right side, white ribbon cable: step 6, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Right side, white ribbon cable: step 6, image 2 of 2
      • Disconnect the white ribbon cable.
      Ask FixBot
    7. Sony WH-1000XM4 Swivel Replacement, Right side, data/pwr connector: step 7, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Right side, data/pwr connector: step 7, image 2 of 2
      • Detach the data/pwr connector from the motherboard using an opening tool.
      Ask FixBot
    8. Sony WH-1000XM4 Swivel Replacement, Right side, motherboard screws: step 8, image 1 of 1
      • Remove the two screws from the motherboard using a Phillips #000 screwdriver.
      Ask FixBot
    9. Sony WH-1000XM4 Swivel Replacement: step 9, image 1 of 3 Sony WH-1000XM4 Swivel Replacement: step 9, image 2 of 3 Sony WH-1000XM4 Swivel Replacement: step 9, image 3 of 3
      • Move the data/pwr cable from the inside of the board to the outside.
      Ask FixBot
    10. Sony WH-1000XM4 Swivel Replacement: step 10, image 1 of 1
      • Remove the data/ pwr connector from board.
      Ask FixBot
    11. Sony WH-1000XM4 Swivel Replacement, Right side, hinge screws: step 11, image 1 of 1
      • On the right ear, rotate the motherboard and remove the two screws from the hinge using a Phillips #000 screwdriver.
      Ask FixBot
    12. Sony WH-1000XM4 Swivel Replacement, Right side, hinge removal: step 12, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Right side, hinge removal: step 12, image 2 of 2
      • On the right ear, lift the hinge and push it out.
      Ask FixBot
    13. Sony WH-1000XM4 Swivel Replacement, Left side, ear muff: step 13, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Left side, ear muff: step 13, image 2 of 2
      • Using an opening tool, pry off the left ear muff and remove the underlying foam.
      Ask FixBot
    14. Sony WH-1000XM4 Swivel Replacement, Left side, screws: step 14, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Left side, screws: step 14, image 2 of 2
      • Remove the four silver screws on left side of the headphones using a Phillips #000 screwdriver.
      Ask FixBot
    15. Sony WH-1000XM4 Swivel Replacement, Left side, cup cover: step 15, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Left side, cup cover: step 15, image 2 of 2
      • Lift up and flip the left ear cup cover.
      Ask FixBot
    16. Sony WH-1000XM4 Swivel Replacement, Left side, multipin connector: step 16, image 1 of 1
      • On the left ear, detach the multipin connector (multiple colorful wires) from the back panel to the motherboard.
      Ask FixBot
    17. Sony WH-1000XM4 Swivel Replacement, Left side, hinge screws: step 17, image 1 of 1
      • On the left ear, remove the two screws from the hinge using a Phillips #000 screwdriver.
      Ask FixBot
    18. Sony WH-1000XM4 Swivel Replacement, Left side, hinge removal: step 18, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Left side, hinge removal: step 18, image 2 of 2
      • On the left ear, lift the hinge and push it out.
      Ask FixBot
    19. Sony WH-1000XM4 Swivel Replacement, Commons steps, hinge removal: step 19, image 1 of 2 Sony WH-1000XM4 Swivel Replacement, Commons steps, hinge removal: step 19, image 2 of 2
      • Remove the black hinge piece from the data/ pwr cable.
      Ask FixBot
    20. Sony WH-1000XM4 Swivel Replacement: step 20, image 1 of 2 Sony WH-1000XM4 Swivel Replacement: step 20, image 2 of 2
      • Using a screwdriver, remove the rubber band.
      Ask FixBot
    21. Sony WH-1000XM4 Swivel Replacement: step 21, image 1 of 2 Sony WH-1000XM4 Swivel Replacement: step 21, image 2 of 2
      • Use an opening tool to remove the cover.
      Ask FixBot
    22. Sony WH-1000XM4 Swivel Replacement: step 22, image 1 of 1
      • Lift up the data/ pwr cable.
      Ask FixBot
    23. Sony WH-1000XM4 Swivel Replacement: step 23, image 1 of 1
      • Remove the two screws from the swivel using a Phillips #000 screwdriver.
      Ask FixBot
    24. Sony WH-1000XM4 Swivel Replacement: step 24, image 1 of 2 Sony WH-1000XM4 Swivel Replacement: step 24, image 2 of 2
      • Push out the metal bit from the swivel piece using a spudger.
      • Pull out the metal bit.
      Ask FixBot
    25. Sony WH-1000XM4 Swivel Replacement: step 25, image 1 of 2 Sony WH-1000XM4 Swivel Replacement: step 25, image 2 of 2
      • Remove the old swivel.
      Ask FixBot
31 other people completed this guide.
Jian Mejia
1,075 Reputation
1 Guide authored
16 Guide Comments
really helpful, thank you! my swivel snapped. I started from Step 18 and removed the cover halfway. re-inserted the swivel then locked the metal bit back. i don't have the replacement piece and it will snap again if twisted too far, but this works for now. thanks!!
jianne - Reply Share
Here are a few suggestions:
1) Do a google search for 'sony headphones wh1000xm4 replacement plastics'
2) SONY Replacement Parts Website (what they offer) I found at this site.
3) Joe's SONY WH-1000XM4 Repair Parts I found at this site.
- The individual part you needed is offered along with a replacement metal clip.⏎
4) Check eBay - Currently (2/9/24) I see the part you need along with the two piece that attaches from the swivel joint to the speaker for about $11.99 USD
sonnyhung - Reply Share
I hear a creaking sound on my left earcup and have tried everything to remove it (tape, lube, opening the sides up) but to no avail. Should I do this guide and check if the creaking is in the hinge part? Thanks.
EJ Vinuya (EJ) - Reply Share
I think you should because mine were making that sound for a while before they broke
Maria Demina - Reply Share
ok, got it all off!.....how do i put on a replacement?
elizabeth “liz” Lopez - Reply Share
Past 24 Hours: 61
Past 7 Days: 450
Past 30 Days: 1,613
All Time: 36,375
