Sony WH-1000XM4 Ear Pads Replacement
  1. Sony WH-1000XM4 Ear Pads Replacement, Place the headphones speakers-up: step 1, image 1 of 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
    Ask FixBot
  2. Sony WH-1000XM4 Ear Pads Replacement, Create a gap: step 2, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Create a gap: step 2, image 2 of 2
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    Ask FixBot
  3. Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: step 3, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: step 3, image 2 of 2
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
    Ask FixBot
  4. Sony WH-1000XM4 Ear Pads Replacement: step 4, image 1 of 3 Sony WH-1000XM4 Ear Pads Replacement: step 4, image 2 of 3 Sony WH-1000XM4 Ear Pads Replacement: step 4, image 3 of 3
    • Repeat the previous step around the perimeter of the ear cup to disconnect the remaining clips.
    Ask FixBot
  5. Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: step 5, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: step 5, image 2 of 2
    • Remove the left ear pad.
    Ask FixBot
  6. Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: step 6, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: step 6, image 2 of 2
    • When installing a replacement left ear pad:
    • Align the cushion over the speaker and press them firmly together to snap it into place.
    • Press around the entire edge of the cushion, making sure all the clips have engaged.
    Ask FixBot
  7. Sony WH-1000XM4 Ear Pads Replacement, Create a gap: step 7, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Create a gap: step 7, image 2 of 2
    • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    Ask FixBot
  8. Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: step 8, image 1 of 3 Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: step 8, image 2 of 3 Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: step 8, image 3 of 3
    • When the first clip disconnects, you'll hear an audible clicking sound.
    Ask FixBot
  9. Sony WH-1000XM4 Ear Pads Replacement: step 9, image 1 of 3 Sony WH-1000XM4 Ear Pads Replacement: step 9, image 2 of 3 Sony WH-1000XM4 Ear Pads Replacement: step 9, image 3 of 3
    Ask FixBot
  10. Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: step 10, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: step 10, image 2 of 2
    • Remove the right ear pad.
    Ask FixBot
  11. Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: step 11, image 1 of 2 Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: step 11, image 2 of 2
    • When installing a replacement right ear pad:
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
48 other people completed this guide.
Carsten Frauenheim
167,197 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
18 Guide Comments
This is a great guide!
it is also the solution to the ticking problem on the left ear cup!
there is a small cable linking the microphone to the headset that is beneath the earcup. it has a small holder that should prevent it from moving.
if it’s not attached properly, the noise canceling will start ticking every few seconds in a very annoying way.
removing the earcup and cleaning there is the best solution I found!
Thanks a lot for the amazing guide!!
Sapir Havusha-Laufer - Reply Share
I was having a similar issue where the right ear cup was making an annoying scratching sound. Turned out to be a hair that was stuck in and brushing against the speaker. Fixed by opening and removing with tweezers!
spencer - Reply Share
Very comprehensible instructions, thank you! I have rather the problem that the original ear pads are not available anywhere and are not shipped to Germany by Sony. Does anyone have a tip on how to get the replacement pads or any idea which third-party pads can be recommendet?
Larkus Manz - Reply Share
Where can I buy official replacement earpads?
Arne Vandervorst - Reply Share
i also need to know that, i found some OEM on amazon, but i don't trust any of them
Nicolas Silva A. - Reply Share
Past 24 Hours: 73
Past 7 Days: 488
Past 30 Days: 2,412
All Time: 159,274
