Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓This tutorial demonstrates how to swap out the Sony WF-1000XM3 earphones' main board. The main board might be affected if, after testing and swapping out other parts like the speaker or battery, the earphones still don't turn on. Damage to its tiny parts, either mechanical or electrical, may be the cause of this problem. It takes patience and a reasonable level of technical expertise to replace the main board.
Before you begin this repair, make sure your earbuds are turned off and you remove the batteries.
Caution: This repair requires soldering to remove the main board. For instructions and safety tips on soldering and desoldering, review this guide.
Tools
Use the spudger and tweezers to remove the small connectors that hold the main board in place.
If your device contains soldered components, carefully desolder them with the soldering iron.
Gently remove the main board.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
