Sony WF-1000XM3 Case Battery Replacement
    1. Sony WF-1000XM3 Case Battery Replacement, Case Battery: step 1, image 1 of 3 Sony WF-1000XM3 Case Battery Replacement, Case Battery: step 1, image 2 of 3 Sony WF-1000XM3 Case Battery Replacement, Case Battery: step 1, image 3 of 3
      • Use plastic opening picks to release the locking mechanism that secures the plastic shell of the charging case to its internal components.
      • Use a spudger to release the final lock and slide out the internal components of the charging case.
      Ask FixBot
    2. Sony WF-1000XM3 Case Battery Replacement: step 2, image 1 of 3 Sony WF-1000XM3 Case Battery Replacement: step 2, image 2 of 3 Sony WF-1000XM3 Case Battery Replacement: step 2, image 3 of 3
      • Use the point of a spudger to push on alternating sides of each connector to "walk" it out of its socket.
      • Do not pull on the cables as they may come loose.
      • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
      Ask FixBot
    3. Sony WF-1000XM3 Case Battery Replacement: step 3, image 1 of 2 Sony WF-1000XM3 Case Battery Replacement: step 3, image 2 of 2
      • Use a plastic spudger to carefully remove the battery from the double-sided tape securing it in place, then remove it from the battery compartment.
      Ask FixBot
    4. Sony WF-1000XM3 Case Battery Replacement: step 4, image 1 of 2 Sony WF-1000XM3 Case Battery Replacement: step 4, image 2 of 2
      • Remove the two metal 3 mm screws from the motherboard using a Phillips #000 screwdriver.
      • Remove the motherboard and battery assembly from the battery case
      Ask FixBot
    5. Sony WF-1000XM3 Case Battery Replacement: step 5, image 1 of 2 Sony WF-1000XM3 Case Battery Replacement: step 5, image 2 of 2
      • Desolder the red and black wires that connect the battery to the motherboard.
      • Solder the wires from the replacement battery into the circuit board following the same configuration.
      • Position the battery so that the raised section faces inward, allowing the case to fully seal.
      • Do not let ends of the wires of either battery touch, as they may spark and cause a fire.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 other people completed this guide.
WyattC
502 Reputation
4 Guides authored
UMass Dartmouth, Team 3-6, Santin Fall 2024 Member of UMass Dartmouth, Team 3-6, Santin Fall 2024
UMASSD-SANTIN-F24S3G6
3 Members
48 Guides authored
4 Guide Comments
what kind of battery is in the case?
Bóas Kár Ketilsson - Reply Share
What is the battery model of the battery?
Rafael Romero Flores - Reply Share
14500 3.7v, as seen in the battery label on Step 2
Tim Spanjersberg - Reply Share
Has anyone had any success getting the case flush again? I've done cable management and the battery wires are out of the way and stuck down but the outer shell does not want to go back flush.
Spencer Montagu - Reply Share
Past 24 Hours: 15
Past 7 Days: 111
Past 30 Days: 429
All Time: 7,819
