Up to 20% off select tools
Sony Vaio VPCW21FX RAM Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
87
All Time:
4,359
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this guide, you will learn how to remove and replace the RAM Memory Chips from your laptop. If you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the RAM Memory Chips and you can adapt them to your own computer.
    1. Sony Vaio VPCW21FX RAM Replacement, Battery: step 1, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement, Battery: step 1, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement, Battery: step 1, image 3 of 3
      • Be sure to disconnect the device charger and power down the device before beginning.
      • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
      Ask FixBot
    2. Sony Vaio VPCW21FX RAM Replacement: step 2, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement: step 2, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement: step 2, image 3 of 3
      • Slide the "release" switch to the left and gently lift the battery up to remove it.
      • Completely remove the battery from the device.
      Ask FixBot
    1. Sony Vaio VPCW21FX RAM Replacement, RAM: step 3, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement, RAM: step 3, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement, RAM: step 3, image 3 of 3
      • Loosen but do not remove the screw over RAM cover panel.
      • With the screw loosened but not removed, lift up and remove the panel.
      Ask FixBot
    2. Sony Vaio VPCW21FX RAM Replacement: step 4, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement: step 4, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement: step 4, image 3 of 3
      • Locate the mounting bracket holding the RAM Chips in the computer.
      • Pull silver tabs away from the chip.
      • The chip will pop up, this is normal.
      • Don't touch gold pins on RAM chip.
      Ask FixBot
    3. Sony Vaio VPCW21FX RAM Replacement: step 5, image 1 of 2 Sony Vaio VPCW21FX RAM Replacement: step 5, image 2 of 2
      • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
      • Repeat previous steps for second RAM chip.
      Ask FixBot
Author
with
Nicholas Corcoran
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 87
All Time: 4,359
