Sony Vaio VPCW21FX Keyboard Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
101
All Time:
3,024
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, you will learn how to remove and replace the Keyboard from your laptop. If you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the Keyboard and you can adapt them to your own computer.
Tools
    1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: step 1, image 1 of 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: step 1, image 2 of 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: step 1, image 3 of 3
      • Be sure to disconnect the device charger and power down the device before beginning.
      • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
      Ask FixBot
    2. Sony Vaio VPCW21FX Keyboard Replacement: step 2, image 1 of 3 Sony Vaio VPCW21FX Keyboard Replacement: step 2, image 2 of 3 Sony Vaio VPCW21FX Keyboard Replacement: step 2, image 3 of 3
      • Slide the "release" switch to the left and gently lift the battery up to remove it.
      • Completely remove the battery from the device.
      Ask FixBot
    1. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: step 3, image 1 of 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: step 3, image 2 of 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Open the Lid of the laptop
      • Then using they pry tool to carefully remove the plastic cover around the keyboard
      • It helps to pry from one of the larger keys as they have more room to fit the tool in
      Ask FixBot
    2. Sony Vaio VPCW21FX Keyboard Replacement: step 4, image 1 of 3 Sony Vaio VPCW21FX Keyboard Replacement: step 4, image 2 of 3 Sony Vaio VPCW21FX Keyboard Replacement: step 4, image 3 of 3
      • Close the lid and flip the laptop over
      • Loosen but do not remove the screw on center panel and remove Panel.
      Ask FixBot
    3. Sony Vaio VPCW21FX Keyboard Replacement: step 5, image 1 of 2 Sony Vaio VPCW21FX Keyboard Replacement: step 5, image 2 of 2
      • Remove the three 5mm screws that are holding in the keyboard.
      Ask FixBot
    4. Sony Vaio VPCW21FX Keyboard Replacement: step 6, image 1 of 3 Sony Vaio VPCW21FX Keyboard Replacement: step 6, image 2 of 3 Sony Vaio VPCW21FX Keyboard Replacement: step 6, image 3 of 3
      • Flip laptop over again and open the lid
      • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
      • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
      Ask FixBot
Nicholas Corcoran
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 101
All Time: 3,024
