Sony Vaio VPCW211AX Keyboard Replacement
    1. Sony Vaio VPCW211AX Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Start with the laptop face up on a flat surface.
      Ask FixBot
    2. Sony Vaio VPCW211AX Keyboard Replacement: step 2, image 1 of 1
      • Open the laptop with the keyboard facing you.
      Ask FixBot
    3. Sony Vaio VPCW211AX Keyboard Replacement: step 3, image 1 of 2 Sony Vaio VPCW211AX Keyboard Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
      • Be careful around the edges; work your way around the keyboard until all of it is detached.
      • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
      Ask FixBot
    4. Sony Vaio VPCW211AX Keyboard Replacement: step 4, image 1 of 2 Sony Vaio VPCW211AX Keyboard Replacement: step 4, image 2 of 2
      • Carefully detach the ribbon from the base of the computer with your hands.
      • Remove the keyboard.
      Ask FixBot
Giselle Dougan
760 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 67
All Time: 959
