Sony Vaio VPCW211AX Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
72
All Time:
1,156
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to replace the fan in your Sony Vaio computer. You will need to have completed the keyboard replacement guide first.
Parts
Tools
    1. Sony Vaio VPCW211AX Fan Replacement, Keyboard: step 1, image 1 of 1
      • Start with the laptop face up on a flat surface.
      Ask FixBot
    2. Sony Vaio VPCW211AX Fan Replacement: step 2, image 1 of 1
      • Open the laptop with the keyboard facing you.
      Ask FixBot
    3. Sony Vaio VPCW211AX Fan Replacement: step 3, image 1 of 2 Sony Vaio VPCW211AX Fan Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
      • Be careful around the edges; work your way around the keyboard until all of it is detached.
      • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
      Ask FixBot
    4. Sony Vaio VPCW211AX Fan Replacement: step 4, image 1 of 2 Sony Vaio VPCW211AX Fan Replacement: step 4, image 2 of 2
      • Carefully detach the ribbon from the base of the computer with your hands.
      • Remove the keyboard.
      Ask FixBot
    1. Sony Vaio VPCW211AX Fan Replacement, Fan: step 5, image 1 of 1
      • Use a Philips #0 screwdriver to remove the 7 top case screws.
      Ask FixBot
    2. Sony Vaio VPCW211AX Fan Replacement: step 6, image 1 of 1
      • Using a metal spudger, pry open at the seams.
      • Open the gray top of the laptop from the base black portion.
      • Slide the spudger along the seam, and then carefully open the top.
      Ask FixBot
    3. Sony Vaio VPCW211AX Fan Replacement: step 7, image 1 of 2 Sony Vaio VPCW211AX Fan Replacement: step 7, image 2 of 2
      • Open the top carefully without disconnecting the two parts.
      • Be mindful and careful of the ribbon cable attaching the two parts together.
      Ask FixBot
    4. Sony Vaio VPCW211AX Fan Replacement: step 8, image 1 of 1
      • Use a Philips #0 screwdriver to unscrew the 4 heatsink screws.
      Ask FixBot
    5. Sony Vaio VPCW211AX Fan Replacement: step 9, image 1 of 1
      • If there is electrical tape, remove it with your finger.
      Ask FixBot
    6. Sony Vaio VPCW211AX Fan Replacement: step 10, image 1 of 1
      • Using the plastic opening tool, pry up the unscrewed fan.
      Ask FixBot
    7. Sony Vaio VPCW211AX Fan Replacement: step 11, image 1 of 2 Sony Vaio VPCW211AX Fan Replacement: step 11, image 2 of 2
      • The fan will still be attached by a small red and yellow wire, with your fingers detach this carefully.
      • Remove the fan.
      Ask FixBot
Giselle Dougan
760 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 1,156
