Sony Vaio VPCF2390X Optical Drive Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
62
All Time:
1,017
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you are experiencing trouble with your optical drive, you may need to use this guide in order to replace it. This is a beginner level process. There is no background knowledge or special requirements you need in order to successfully replace your optical drive.
Tools
    1. Sony Vaio VPCF2390X Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Remove the first of two screws located at the marker in the photo.
      Ask FixBot
    2. Sony Vaio VPCF2390X Optical Drive Replacement: step 2, image 1 of 1
      • Remove the second of the two screws located at the marker in the photo.
      Ask FixBot
    3. Sony Vaio VPCF2390X Optical Drive Replacement: step 3, image 1 of 1
      • Grab and slide out the tray from the side of the laptop after both screws have been removed.
      Ask FixBot
    4. Sony Vaio VPCF2390X Optical Drive Replacement: step 4, image 1 of 1
      • Slide in new CD drive and repeat steps 2 and 1 in reverse to screw the new drive down.
      Ask FixBot
Alejandro Lopez
305 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 62
All Time: 1,017
