Sony Vaio VPCF115FM Back Panel Assembly Replacement
    1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: step 1, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over so the bottom is facing up.
      Ask FixBot
    2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 2, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 2, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 2, image 3 of 3
      • Unlock the left tab on the battery.
      • Glide the right battery tab to release the battery pack from the laptop.
      • Keeping the battery tab in the released position, lift the battery up.
      Ask FixBot
    1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: step 3, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: step 3, image 2 of 2
      • Remove the 9mm Phillips #1 screw located on the back cover.
      • Remove cover.
      • Push out metal tabs.
      • Remove card.
      Ask FixBot
    1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Hard Drive: step 4, image 1 of 1
      • Remove two 9mm Phillips #1 screws.
      Ask FixBot
    2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 5, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 5, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 5, image 3 of 3
      • Remove the panel.
      • Gently remove the hard drive.
      • Remove screws securing caddy to hard drive.
      Ask FixBot
    1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: step 6, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: step 6, image 2 of 2
      • Remove the 9mm Phillips #1 screw holding the disk drive in place.
      • Remove the 9mm screw near the memory stick.
      Ask FixBot
    2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 7, image 1 of 1
      • Using an iFixit opening tool, carefully pry the disk drive away from the device.
      Ask FixBot
    1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: step 8, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: step 8, image 2 of 2
      • Remove three 3mm Phillips #1 screws on the side panel.
      Ask FixBot
    2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 9, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 9, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 9, image 3 of 3
      • On the top of the panel, remove four 3mm Phillips #1 screws.
      Ask FixBot
    3. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 10, image 1 of 1
      • Remove the rest of the twelve 9mm Phillips #1 screws on the back panel.
      • Remove the final screw.
      Ask FixBot
    4. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 11, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 11, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 11, image 3 of 3
      • Using an iFixit opening tool, pry the back panel off.
      • At this point, the back panel should very easily pop off.
      • Be careful around mechanical components on the edges of the laptop (audio output, USB ports).
      Ask FixBot
    5. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 12, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 12, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 12, image 3 of 3
      • Continue popping the back panel off.
      • The back panel should now be off.
      Ask FixBot
2 other people completed this guide.
Haylie Hotte
665 Reputation
5 Guides authored
2 Guide Comments
The fan ran at high speed and the laptop would randomly shut down. I suspected a cooling problem. Turned out there was a layer of dust caked on the “fan side” of the cooling fins. I removed the fan/heat sink assembly and used a vacuum and an artist’s brush to clean the fins and fan blades. Put a fresh layer of thermal compound on the CPU and GPU heat sinks and reassembled everything. This back panel removal/replacement instruction page was a great help. Everything went back together successfully and, to my amazement, there were no screws left over!
Wil Higdon - Reply Share
Ganhei um Sony Vaio PCG-81114L usado porem nao tem os parafusos (todos) e nao estou encontrado aqui no Brasil. Tem como ajudar? O procedimento esta 10 e é bem simples. My email: joaocastelor@hotmail.com
joaocastelor - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 69
All Time: 2,347
