Up to 20% off select tools
Sony Vaio VPCEG37FM RAM Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
82
All Time:
2,644
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Sony Vaio VPCEG37FM RAM Replacement, Battery: step 1, image 1 of 1
      • Unlock the battery by sliding the lock upwards.
      Ask FixBot
    2. Sony Vaio VPCEG37FM RAM Replacement: step 2, image 1 of 2 Sony Vaio VPCEG37FM RAM Replacement: step 2, image 2 of 2
      • Slide the release upwards and lift out the battery to remove.
      • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
      • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
      Ask FixBot
    1. Sony Vaio VPCEG37FM RAM Replacement, RAM: step 3, image 1 of 1
      • Use a Phillips #1 screw to unscrew the 6.5 mm screw keeping the cover.
      Ask FixBot
    2. Sony Vaio VPCEG37FM RAM Replacement: step 4, image 1 of 1
      • Gently lift cover up to expose the RAM.
      • Screw will stay attached to cover when being removed.
      Ask FixBot
    3. Sony Vaio VPCEG37FM RAM Replacement: step 5, image 1 of 1
      • Pull the clips, holding the RAM in place, to the side to pop the RAM out. Then remove the RAM.
      • Avoid contact with black squares. Hand oils may damage memory.
      Ask FixBot
Author
with
Brayelly Servellon
121 Reputation
1 Guide authored
2 Guide Comments
This is exact model for my sony vaio. I upgraded ram from 4gb to 2× 4gb sticks (8gb). I was told by electronic store agent to use a faster stick (12800) instead of OEM (10600). Now laptop will not completely stay turned on, even when I go back to just the original 4gb OEM stick in original slot. Any help?
Dan Amaz. - Reply Share
It is possible that you shorted out your computer. This tutorial does not explain the importance of removing the battery from the computer AND discharging the remaining power inside of the computer by holding the power button for 30-60s and most importantly, making sure you are wearing an ESD bracelet to a grounded connection. Static electricity most likely shorted the board. I would bring it to a professional.
Heavy Pour - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 82
All Time: 2,644
