Sony Vaio VPCEG26FX Back Panel Replacement
    1. Sony Vaio VPCEG26FX Back Panel Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so the bottom is facing up with the model number visible.
      Ask FixBot
    2. Sony Vaio VPCEG26FX Back Panel Replacement: step 2, image 1 of 2 Sony Vaio VPCEG26FX Back Panel Replacement: step 2, image 2 of 2
      • Slide the lock switch down until you hear a click to unlock the battery.
      Ask FixBot
    3. Sony Vaio VPCEG26FX Back Panel Replacement: step 3, image 1 of 2 Sony Vaio VPCEG26FX Back Panel Replacement: step 3, image 2 of 2
      • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
      Ask FixBot
    4. Sony Vaio VPCEG26FX Back Panel Replacement: step 4, image 1 of 2 Sony Vaio VPCEG26FX Back Panel Replacement: step 4, image 2 of 2
      • Remove the battery from the battery compartment.
      Ask FixBot
    1. Sony Vaio VPCEG26FX Back Panel Replacement, Hard Drive: step 5, image 1 of 1
      • Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
      • These screws cannot be removed.
      Ask FixBot
    2. Sony Vaio VPCEG26FX Back Panel Replacement: step 6, image 1 of 1
      • Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
      Ask FixBot
    3. Sony Vaio VPCEG26FX Back Panel Replacement: step 7, image 1 of 1
      • Push the hard drive towards the optical reader to unlock it.
      Ask FixBot
    4. Sony Vaio VPCEG26FX Back Panel Replacement: step 8, image 1 of 1
      • Remove the hard drive from the device.
      Ask FixBot
    1. Sony Vaio VPCEG26FX Back Panel Replacement, RAM: step 9, image 1 of 1
      • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
      Ask FixBot
    2. Sony Vaio VPCEG26FX Back Panel Replacement: step 10, image 1 of 1
      • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
      Ask FixBot
    3. Sony Vaio VPCEG26FX Back Panel Replacement: step 11, image 1 of 3 Sony Vaio VPCEG26FX Back Panel Replacement: step 11, image 2 of 3 Sony Vaio VPCEG26FX Back Panel Replacement: step 11, image 3 of 3
      • Remove the green circuit board by dislodging the circuit it is attached to.
      • Unhook it and remove it from the device.
      Ask FixBot
    1. Sony Vaio VPCEG26FX Back Panel Replacement, Back Panel: step 12, image 1 of 1
      • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
      Ask FixBot
    2. Sony Vaio VPCEG26FX Back Panel Replacement: step 13, image 1 of 2 Sony Vaio VPCEG26FX Back Panel Replacement: step 13, image 2 of 2
      • Remove the back panel from the device.
      Ask FixBot
Sara Alfaro
561 Reputation
5 Guides authored
1 Guide Comment
English:
Hello, I don't know if anyone still answers but I need to know something about my Sony Vaio laptop Model PCG-61A14L, Product name:VPCEG34FX there is no information about this laptop
Spanish:
Hola no sé si aún alguien responde pero necesito saber algo sobre mi laptop Sony Vaio Modelo PCG-61A14L, Product name:VPCEG34FX no hay ninguna información de este portátil
Alex - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 78
All Time: 1,583
