Up to 20% off select tools
Sony Vaio VPCEG26FX RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
56
All Time:
1,254
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Through the use of this guide, you will be able to successfully remove the RAM from a Sony Vaio VPCEG26FX laptop. Please see pre-requisite guides in order to aid in your replacement efforts. The RAM will need to be replaced if the laptop runs exceptionally slow or programs unexpectedly crash. Ensure that the RAM is the SO-DIMM standard. Be careful to push back the pins holding the RAM in place. The RAM should move when these pins are moved correctly.
    1. Sony Vaio VPCEG26FX  RAM Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so the bottom is facing up with the model number visible.
      Ask FixBot
    2. Sony Vaio VPCEG26FX  RAM Replacement: step 2, image 1 of 2 Sony Vaio VPCEG26FX  RAM Replacement: step 2, image 2 of 2
      • Slide the lock switch down until you hear a click to unlock the battery.
      Ask FixBot
    3. Sony Vaio VPCEG26FX  RAM Replacement: step 3, image 1 of 2 Sony Vaio VPCEG26FX  RAM Replacement: step 3, image 2 of 2
      • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
      Ask FixBot
    4. Sony Vaio VPCEG26FX  RAM Replacement: step 4, image 1 of 2 Sony Vaio VPCEG26FX  RAM Replacement: step 4, image 2 of 2
      • Remove the battery from the battery compartment.
      Ask FixBot
    1. Sony Vaio VPCEG26FX  RAM Replacement, RAM: step 5, image 1 of 1
      • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
      Ask FixBot
    2. Sony Vaio VPCEG26FX  RAM Replacement: step 6, image 1 of 1
      • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
      Ask FixBot
    3. Sony Vaio VPCEG26FX  RAM Replacement: step 7, image 1 of 3 Sony Vaio VPCEG26FX  RAM Replacement: step 7, image 2 of 3 Sony Vaio VPCEG26FX  RAM Replacement: step 7, image 3 of 3
      • Remove the green circuit board by dislodging the circuit it is attached to.
      • Unhook it and remove it from the device.
      Ask FixBot
Author
with
Sara Alfaro
561 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 56
All Time: 1,254
