Sony Vaio VPCEB11FM Wifi Card Replacement
    1. Sony Vaio VPCEB11FM Wifi Card Replacement, Battery: step 1, image 1 of 1
      • Power down and disconnect the laptop from power supply.
      • Using your fingers, unlock the tab by pushing on the slide.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Wifi Card Replacement: step 2, image 1 of 1
      • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Wifi Card Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Wifi Card Replacement, RAM: step 4, image 1 of 2 Sony Vaio VPCEB11FM Wifi Card Replacement, RAM: step 4, image 2 of 2
      • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
      • Once the cover has been loosened, pry the cover with your finger for it to come off.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Wifi Card Replacement: step 5, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 5, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 5, image 3 of 3
      • Use your fingers to gently pull the white plastic strip outward on both sides.
      • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
      • Once done with the top strip of RAM continue for all continuous strips.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Wifi Card Replacement, Hard Drive: step 6, image 1 of 2 Sony Vaio VPCEB11FM Wifi Card Replacement, Hard Drive: step 6, image 2 of 2
      • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Wifi Card Replacement: step 7, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 7, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 7, image 3 of 3
      • Use your fingers to pry the cover upward.
      • Unscrew the two 7mm screws.
      • Pull the plastic tab in the direction of the arrow to take out.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Wifi Card Replacement: step 8, image 1 of 2 Sony Vaio VPCEB11FM Wifi Card Replacement: step 8, image 2 of 2
      • Lift plug side first.
      • Remove all the way.
      Ask FixBot
    4. Sony Vaio VPCEB11FM Wifi Card Replacement: step 9, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 9, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 9, image 3 of 3
      • Skip to next step if accessing other components.
      • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Wifi Card Replacement, DVD Drive: step 10, image 1 of 2 Sony Vaio VPCEB11FM Wifi Card Replacement, DVD Drive: step 10, image 2 of 2
      • Remove the 7mm screws with the Phillips #1 Screwdriver.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Wifi Card Replacement: step 11, image 1 of 1
      • Grasp the DVD drive's face plate with your fingers and pull out.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Wifi Card Replacement, Cooling Fan: step 12, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement, Cooling Fan: step 12, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement, Cooling Fan: step 12, image 3 of 3
      • Remove ten 7mm screws with the Phillips #1 Screwdriver.
      • Remove two 8mm screws with the Phillips #1 Screwdriver.
      • Remove two 3mm screws with the Phillips #1 Screwdriver.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Wifi Card Replacement: step 13, image 1 of 2 Sony Vaio VPCEB11FM Wifi Card Replacement: step 13, image 2 of 2
      • Remove SD card slot block by pushing it in until it releases.
      • Once released pull out to remove.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Wifi Card Replacement: step 14, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 14, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 14, image 3 of 3
      • To take off the cover plate, start by finding a loose corner to begin prying it open.
      • Work the tool around the sides to release the cover. You may need a second tool to help keep your loose corner open.
      • Lift cover away.
      • NOTE: If you are attempting to access other components, skip 2 steps.
      Ask FixBot
    4. Sony Vaio VPCEB11FM Wifi Card Replacement: step 15, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 15, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 15, image 3 of 3
      • Remove the plug shown using a pry tool.
      • Remove seven 5mm screws with the Phillips #01 Screwdriver.
      Ask FixBot
    5. Sony Vaio VPCEB11FM Wifi Card Replacement: step 16, image 1 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 16, image 2 of 3 Sony Vaio VPCEB11FM Wifi Card Replacement: step 16, image 3 of 3
      • To break the thermal paste, apply gentle constant upward force until it comes free.
      • Remove four 3.5mm screws with the Phillips #000 Screwdriver to access cooling fan.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Wifi Card Replacement, Wifi Card: step 17, image 1 of 1
      • Continuing from Step 3.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Wifi Card Replacement: step 18, image 1 of 1
      • Carefully remove the antenna plugs.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Wifi Card Replacement: step 19, image 1 of 2 Sony Vaio VPCEB11FM Wifi Card Replacement: step 19, image 2 of 2
      • Remove the 3mm screw with the Phillips #01 Screwdriver
      Ask FixBot
    4. Sony Vaio VPCEB11FM Wifi Card Replacement: step 20, image 1 of 1
      • Remove the Wifi Card.
      Ask FixBot
2 other people completed this guide.
Maxine Filcher
1,153 Reputation
8 Guides authored
UW Tacoma, Team 1-5, Rose Winter 2017 Member of UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 2,436
