Sony Vaio VPCEB11FM Keyboard Replacement
    1. Sony Vaio VPCEB11FM Keyboard Replacement, Battery: step 1, image 1 of 1
      • Power down and disconnect the laptop from power supply.
      • Using your fingers, unlock the tab by pushing on the slide.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Keyboard Replacement: step 2, image 1 of 1
      • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Keyboard Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: step 4, image 1 of 2 Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: step 4, image 2 of 2
      • Remove the 7mm screws with the Phillips #1 Screwdriver.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Keyboard Replacement: step 5, image 1 of 1
      • Grasp the DVD drive's face plate with your fingers and pull out.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: step 6, image 1 of 3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: step 6, image 2 of 3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: step 6, image 3 of 3
      • Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
      • The keyboard may need to be loosened on its edges with a plastic spudger.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Keyboard Replacement: step 7, image 1 of 3 Sony Vaio VPCEB11FM Keyboard Replacement: step 7, image 2 of 3 Sony Vaio VPCEB11FM Keyboard Replacement: step 7, image 3 of 3
      • Carefully pull the keyboard back to expose ribbon connector.
      • Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
      Ask FixBot
Maxine Filcher
1,153 Reputation
8 Guides authored
UW Tacoma, Team 1-5, Rose Winter 2017 Member of UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 113
All Time: 2,463
