Sony Vaio VPCEB11FM Hard Drive Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
105
All Time:
5,268
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Sony Vaio VPCEB11FM Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Power down and disconnect the laptop from power supply.
      • Using your fingers, unlock the tab by pushing on the slide.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Hard Drive Replacement: step 2, image 1 of 1
      • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Hard Drive Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
      Ask FixBot
    2. Sony Vaio VPCEB11FM Hard Drive Replacement: step 5, image 1 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 5, image 2 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 5, image 3 of 3
      • Use your fingers to pry the cover upward.
      • Unscrew the two 7mm screws.
      • Pull the plastic tab in the direction of the arrow to take out.
      Ask FixBot
    3. Sony Vaio VPCEB11FM Hard Drive Replacement: step 6, image 1 of 2 Sony Vaio VPCEB11FM Hard Drive Replacement: step 6, image 2 of 2
      • Lift plug side first.
      • Remove all the way.
      Ask FixBot
    4. Sony Vaio VPCEB11FM Hard Drive Replacement: step 7, image 1 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 7, image 2 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 7, image 3 of 3
      • Skip to next step if accessing other components.
      • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
      Ask FixBot
2 other people completed this guide.
Maxine Filcher
1,153 Reputation
8 Guides authored
UW Tacoma, Team 1-5, Rose Winter 2017 Member of UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 105
All Time: 5,268
