Up to 20% off select tools
Sony Vaio VPCCW17FX RAM Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
88
All Time:
1,865
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
In order to remove the RAM safely, be sure to take out the battery first. The RAM is under a panel on the laptop and can be ejected by hand.
    1. Sony Vaio VPCCW17FX RAM Replacement, RAM: step 1, image 1 of 1
      • Turn the laptop over and orient it as shown.
      Ask FixBot
    2. Sony Vaio VPCCW17FX RAM Replacement: step 2, image 1 of 1
      • Slide both latches to the center of the laptop in order to release the battery.
      Ask FixBot
    3. Sony Vaio VPCCW17FX RAM Replacement: step 3, image 1 of 2 Sony Vaio VPCCW17FX RAM Replacement: step 3, image 2 of 2
      • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
      Ask FixBot
    4. Sony Vaio VPCCW17FX RAM Replacement: step 4, image 1 of 2 Sony Vaio VPCCW17FX RAM Replacement: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
      Ask FixBot
    5. Sony Vaio VPCCW17FX RAM Replacement: step 5, image 1 of 1
      • Lift the black plastic cover to assess the RAM.
      Ask FixBot
    6. Sony Vaio VPCCW17FX RAM Replacement: step 6, image 1 of 3 Sony Vaio VPCCW17FX RAM Replacement: step 6, image 2 of 3 Sony Vaio VPCCW17FX RAM Replacement: step 6, image 3 of 3
      • Apply light, outward pressure to the locks on both sides of the RAM.
      • Rotate the RAM up and slowly pull towards you to remove it.
      Ask FixBot
    7. Sony Vaio VPCCW17FX RAM Replacement: step 7, image 1 of 3 Sony Vaio VPCCW17FX RAM Replacement: step 7, image 2 of 3 Sony Vaio VPCCW17FX RAM Replacement: step 7, image 3 of 3
      • In order to remove the secondary RAM, use the same outward pressure on the locks.
      • Lift and slide out the RAM to remove it from the slot.
      Ask FixBot
Author
with
Mia Martinez
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 88
All Time: 1,865
