Sony Vaio VPCCW17FX LCD Screen Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
98
All Time:
1,666
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
In order to remove the screen safely, be sure to take out the battery first. The screen can be replaced once you remove the plastic cover located on the back of the laptop with all screws removed.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Turn the laptop over and orient it as shown.
      Ask FixBot
    2. Sony Vaio VPCCW17FX LCD Screen Replacement: step 2, image 1 of 1
      • Slide both latches towards the center of the battery to release.
      Ask FixBot
    3. Sony Vaio VPCCW17FX LCD Screen Replacement: step 3, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 3, image 2 of 2
      • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
      Ask FixBot
    4. Sony Vaio VPCCW17FX LCD Screen Replacement: step 4, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 4, image 2 of 2
      • Remove the rubber pads on all four corners of the screen bezel using the spudger.
      • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
      Ask FixBot
    5. Sony Vaio VPCCW17FX LCD Screen Replacement: step 5, image 1 of 1
      • Remove the screen's plastic bezel.
      • You need to use slight pressure to release the clips.
      Ask FixBot
    6. Sony Vaio VPCCW17FX LCD Screen Replacement: step 6, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 6, image 2 of 2
      • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
      • Using your thumb, carefully lower the glass and place it on the keyboard.
      • Do this slowly to avoid damaging the screen.
      Ask FixBot
    7. Sony Vaio VPCCW17FX LCD Screen Replacement: step 7, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 7, image 2 of 2
      • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
      Ask FixBot
    8. Sony Vaio VPCCW17FX LCD Screen Replacement: step 8, image 1 of 1
      • The screen can now be removed.
      Ask FixBot
Seowon Song
113 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 98
All Time: 1,666
