Sony Vaio VPCCW17FX Fan Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
71
All Time:
1,566
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide provides users with a step-by-step process for accessing and replacing the fan component. This guide will be helpful to users who need to clean the fan or replace a damaged fan.
Tools
    1. Sony Vaio VPCCW17FX Fan Replacement, Back case: step 1, image 1 of 1
      • Turn the laptop over and orient it as shown.
      Ask FixBot
    2. Sony Vaio VPCCW17FX Fan Replacement: step 2, image 1 of 3 Sony Vaio VPCCW17FX Fan Replacement: step 2, image 2 of 3 Sony Vaio VPCCW17FX Fan Replacement: step 2, image 3 of 3
      • Remove the battery by pinching the two lock tabs towards the center.
      • Next, lift up on the battery to remove it.
      Ask FixBot
    3. Sony Vaio VPCCW17FX Fan Replacement: step 3, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
      • Be sure to remove all screws, including those that are typically covered by the battery.
      Ask FixBot
    4. Sony Vaio VPCCW17FX Fan Replacement: step 4, image 1 of 3 Sony Vaio VPCCW17FX Fan Replacement: step 4, image 2 of 3 Sony Vaio VPCCW17FX Fan Replacement: step 4, image 3 of 3
      • Now, remove the small covers from the back of the case.
      • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
      • Then, lift up on and remove these covers as shown in the third image.
      Ask FixBot
    5. Sony Vaio VPCCW17FX Fan Replacement: step 5, image 1 of 3 Sony Vaio VPCCW17FX Fan Replacement: step 5, image 2 of 3 Sony Vaio VPCCW17FX Fan Replacement: step 5, image 3 of 3
      • Remove the hard drive.
      • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
      • Next, lift up and pull outwards to release the hard drive from its socket.
      Ask FixBot
    6. Sony Vaio VPCCW17FX Fan Replacement: step 6, image 1 of 1
      • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
      Ask FixBot
    7. Sony Vaio VPCCW17FX Fan Replacement: step 7, image 1 of 1
      • After proper removal of all necessary screws, gently lift up on the back case to remove it.
      Ask FixBot
    1. Sony Vaio VPCCW17FX Fan Replacement, Fan: step 8, image 1 of 3 Sony Vaio VPCCW17FX Fan Replacement, Fan: step 8, image 2 of 3 Sony Vaio VPCCW17FX Fan Replacement, Fan: step 8, image 3 of 3
      • Locate the fan (top-right corner of the computer).
      • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
      Ask FixBot
    2. Sony Vaio VPCCW17FX Fan Replacement: step 9, image 1 of 2 Sony Vaio VPCCW17FX Fan Replacement: step 9, image 2 of 2
      • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
      • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
      Ask FixBot
    3. Sony Vaio VPCCW17FX Fan Replacement: step 10, image 1 of 2 Sony Vaio VPCCW17FX Fan Replacement: step 10, image 2 of 2
      • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 71
All Time: 1,566
